Author Topic: winch issues  (Read 2163 times)
winch issues
« on: November 11, 2009, 04:59:07 PM »
hey i got a power plant and resently it has been a pain in the butt
now i had enough and i ripped it apart and cleaned all the connections and rebuilt it and it still didnt work
by not working i mean some times it will pull in .. other times it will only let out  or it wont work at all and yo ucan hear the click when pressing the button
the air compressor didnt want to work either
so after all the rebuilding i was up set and hit it with a hammer
guess what it works not
so can anyone give some imputt on winch problems
does something need to be replaced or just a loose wire somewhere
Re: winch issues
« Reply #1 on: November 11, 2009, 05:11:58 PM »
tighten your battery terminals.....................
Offline slimbeam
Re: winch issues
« Reply #2 on: November 11, 2009, 06:20:00 PM »
sounds like loose wire somewhere Jeff; I had problem with my winch it would only spool out, I had to take the control button apart and fix a contact wire, as for the compressor like Johnny says check your wire terminals and switches. a multimeter or test light will help some if you got one
Offline Pookapotamus
Re: winch issues
« Reply #3 on: November 11, 2009, 07:02:10 PM »
could be your solenoids, or even your switches if you have a multimeter you can check the switches.
Re: winch issues
« Reply #4 on: November 11, 2009, 08:16:49 PM »
thanks guys ill check the out put with a multimeter .. i know the battery terminals are good and clean
and tight
Re: winch issues
« Reply #5 on: November 11, 2009, 08:29:16 PM »
Do you have a dedicated ground line going from the neg battery post to the winch? Is there a good gnd connection between the solenoid pack and the winch?
On my warn 9.5ti I've had a problem twice now where the brush holder inside the motor loses its gnd contact with the motor case. The brush holder plate is aluminum and the case is steel. Corrosion builds between the two and causes the brush holders to lose their gnd. Fixing it requires removing the motor, taking it apart and cleaning the surface between the holder and case.
Offline Eagle Jeeper
Re: winch issues
« Reply #6 on: November 11, 2009, 09:14:47 PM »
x2 on the dedicated ground a buddy had a 9000 lb that gave him troubles from new.  Put in a dedicated ground and presto.
Re: winch issues
« Reply #7 on: November 11, 2009, 09:19:49 PM »
all the ground seem good .. and it works fine today but bet  you money it wont work tomorrow ..
ill look into the selanoid
maybe its that the plug looks clean and not corroaded ..
Re: winch issues
« Reply #8 on: November 11, 2009, 09:32:37 PM »
The PowerPlant is also a bit more complicated than most winches - there's a sort of  "transmission" that changes the motor from operating the winch drum to operating the compressor. If it's stuck between those two positions, it may be causing you a problem.
Re: winch issues
« Reply #9 on: November 11, 2009, 09:43:19 PM »
If this is the case then its a bigger problem since the clutch piece is plastic and the lever is metal. Sometimes cracks or breaks the little plastic thing in the winch.
Re: winch issues
« Reply #10 on: November 12, 2009, 08:13:38 PM »
it switchs from winch to compressor very easy  no forcing needed .. and when it works it works   but it seems not to work more then it does
Re: winch issues
« Reply #11 on: November 12, 2009, 10:22:05 PM »
Have you tried calling Warn?
Even if it's not under warranty, they may be able to help diagnosing the problem, and tell you exactly where to get any parts you may need...or tell you what to do to fix it...or where to take it for repair.
I've never had to call them myself, by I've heard a lot of good feedback about Warn customer service.
Re: winch issues
« Reply #12 on: November 13, 2009, 03:28:51 AM »
Listen to Todd on this one Jeff. Warn has an excellent technical support line that you can call. I had some issue's with my ancient pre- 8274  winch. The tech. support personnel helped me diagnose the problems over the phone. I managed to get my winch working. It's worth a shot.
Re: winch issues
« Reply #13 on: November 13, 2009, 11:44:34 AM »
More often then not, the remote is the cause of most warn winch issues.
Find another remote and try that, or try your remote in another winch.
Re: winch issues
« Reply #14 on: November 13, 2009, 05:42:15 PM »
thanks boys ill try to track down another remote / ill also give them a call
