Author Topic: Whats normal  (Read 3055 times)
Offline Rookie
Whats normal
« on: December 16, 2005, 10:40:05 PM »
What is the normal amount of play in the front output shaft of the NV231 transfer case  :?:
I was under the jeep tonight checking the u-joints and I found that I have about a 1\2" of up and down play in the front output shaft  :cry:
Normal or not
TIA
Steve
TJ with some stuff
RedYJ
Whats normal
« Reply #1 on: December 16, 2005, 11:04:30 PM »
I have that too I have always woundered the same, its about half a inch or so.
Offline 4low
Whats normal
« Reply #2 on: December 17, 2005, 01:26:24 AM »
Radial play or Lateral?
BTL WGN
Offline Rookie
Whats normal
« Reply #3 on: December 17, 2005, 02:13:26 PM »
Quote from: "4low"
Side to side or up and down
TJ with some stuff
Offline Rookie
Re: Whats normal
« Reply #4 on: December 18, 2005, 08:27:28 PM »
Quote from: "Rookie"
Normal or not
TIA
Steve
Can anyone help me or is there anyone in the north end of the city that has this t-case and is willing to let me crawl under it to shake their front drive shaft :lol:
TJ with some stuff
Offline apex
Whats normal
« Reply #5 on: December 18, 2005, 09:16:34 PM »
I'm in the NE near Peter's drive in. You are welcome to come over after 5;30 pm. Or if you can cut out at work you are welcome 8 am - 5 pm near the Austrian club.  Neither have a heated garage.
My front driveshaft was just recently replaced so it might be a good reference for ya.
*edit* typo
Offline Rookie
Whats normal
« Reply #6 on: December 18, 2005, 10:35:35 PM »
Quote from: "Apex"
Mr front driveshaft was just recently replaced so it might be a good reference for ya.
Greg u have a pm
I've never seen a Mr front drive shaft :lol:  :lol:
Steve
TJ with some stuff
Offline RACKMAN
Whats normal
« Reply #7 on: December 19, 2005, 10:38:24 AM »
I was just under my TJ checking out stufff and found that I have about 1/4" of play in the up and down plane. So if anyone does know if this is normal or if the driveshaft should be 100% tight please let us know.
RACKMAN
Offline Rookie
Whats normal
« Reply #8 on: December 19, 2005, 06:10:56 PM »
Well I checked Apex's jeep and Spinalguy's 97 tj today and there is no noticeable up and down or side to side play :cry:  :cry:  :cry:
Steve
TJ with some stuff
Whats normal
« Reply #9 on: December 19, 2005, 11:25:06 PM »
Since you have noticable "play" at a standstill...What does it feel like at speeds? Any vibrations?
I thought these were held tight with bearings and/or shims, when those start to let go, it gets loose.... But I could be wrong.
Offline Rookie
Whats normal
« Reply #10 on: December 20, 2005, 12:17:04 AM »
Vibrations Oh yeah
I can buy a tims coffee drive a few km's and have one of those fancy coffees with all that foam stuff on top :lol:  :lol:  :lol:
TJ with some stuff
Jasona666
Whats normal
« Reply #11 on: December 20, 2005, 07:15:59 AM »
well jeez you got a fancy making coffee jeep lol
Offline laredo
Whats normal
« Reply #12 on: December 20, 2005, 09:48:24 AM »
sounds like a worn cv ball in the double cardan joint
Pat's driveline has them
