Author Topic: Wow...  (Read 3680 times)
Offline Mudhawg
  • Rig Life
Wow...
« on: November 19, 2009, 04:23:29 PM »
doin tie rod ends for a guy i know in a cherokee.. well thats what im suposed to be doin currently realizing whoever worked on this jeep last is an IDIOT and forgot to tighten the lugnuts at all... SOOOO now the rim is fubar'd and all the studs seem to be broken out of the hub or something, but the wheel is somehow stayin on as i cannot unthread the lugnuts as the studs just spin... any idea's?
Offline Mikes off road
Re: Wow...
« Reply #1 on: November 19, 2009, 04:48:09 PM »
A snipe on the lug nuts and break the studs off. You need to replace them anyways.
Offline Mudhawg
  • Rig Life
Re: Wow...
« Reply #2 on: November 19, 2009, 05:12:42 PM »
tried that they just spin can turn em both ways by finger
Offline Mudhawg
  • Rig Life
Re: Wow...
« Reply #3 on: November 19, 2009, 05:34:44 PM »
thats what i was tryin to say the rim is toast as well as the studs
Offline 2grand4u
Re: Wow...
« Reply #4 on: November 19, 2009, 05:37:41 PM »
get a coulpe GOOD metal blades, cut the rim, then when you got room cut the studs then get a new wheel bearing and a rim, most likly studs too
Re: Wow...
« Reply #5 on: November 19, 2009, 05:50:44 PM »
Let the weight of the vehicle down onto the studs, that might be enough to get the studs loose. Barring that keep driving it till the studs wear down and break and the wheel falls off.  :D
You might be able to unbolt the brake caliper bracket from the knuckle, undo the three unit bearing bolts, undo the axleshaft nut and slide the whole thing off.
Offline Mudhawg
  • Rig Life
Re: Wow...
« Reply #6 on: November 19, 2009, 05:54:28 PM »
Thats almost what i was thinkin cLAY just figured id see if anyone else would agree with me ill try letting the jeep back down and try to get them off.. the guy was complaining it had wobble so he suspected tie rod ends... pretty sure i solved his problem lol
Re: Wow...
« Reply #7 on: November 19, 2009, 05:59:33 PM »
He's going to need a new unit bearing as the holes for the studs will stripped out. Don't forget 5 new lug nuts either.
Offline Pookapotamus
Re: Wow...
« Reply #8 on: November 19, 2009, 07:02:23 PM »
the studs themselves might be turning in their hols so turning the nuts does nothing. do you have access to a torch?
Re: Wow...
« Reply #9 on: November 19, 2009, 07:52:45 PM »
You could drill out the studs/lugnuts, use vise grips to hold the lug nut, but a torch would be real quick. Both sides fubarred?
Offline Mudhawg
  • Rig Life
Re: Wow...
« Reply #10 on: November 19, 2009, 07:56:20 PM »
nah just the passenger side
Re: Wow...
« Reply #11 on: November 19, 2009, 10:40:17 PM »
Hold the rim as straight as possible and weld it to the studs.
Toss a hubcap on, charge him through the nose for the repairs and call it done.
Offline Zombie
  • Jeff the Zombie Jeep
Re: Wow...
« Reply #12 on: November 19, 2009, 11:31:36 PM »
Try letting the vehicle sit on the wheel, if there is enough force on the studs, it might hold them enough to get the nuts off.
just an idea!
Offline esi
Re: Wow...
« Reply #13 on: November 20, 2009, 12:14:12 AM »
you could try to tighten the lugs with an impact, if you can get them to tighten up and stop spinning. Then dril out and tighten again. They should snap off.
Formerly of Boots & Boost Inc
Offline i_go_commando
Re: Wow...
« Reply #14 on: November 20, 2009, 09:39:22 PM »
can you get behind the rim enough to tack the lugs to the break rotor? usualy you can get at one lug nut and turn the wheel to get at all of them
