Author Topic: Question for electricians  (Read 2056 times)
Offline 4PLAYZJ
« on: November 30, 2009, 06:32:03 PM »
Running a sub service to my new garage.  Would like to know what size of conductors to run to the sub panel.  The run is 50' long and will be a 100 amp sub service from a 200 amp panel.
Re: Question for electricians
« Reply #1 on: November 30, 2009, 06:37:39 PM »
I have speaker wire at the house Will if you need.
It was to easy :P
« Reply #2 on: November 30, 2009, 06:43:49 PM »
speaker wire
Exactly what I was going to suggest...
Offline Whips17
« Reply #3 on: November 30, 2009, 06:56:54 PM »
I would use a #2 AL   URD  which is a underground wire,  and drop a ground plate in the ground with a #6 Strand cooper wire for the ground.
80 CJ-7 350 chevy, 8000 Warn winch,  33/12.5 R15 Cooper STT,  True Trac front & Rear,
Offline Rookie
« Reply #4 on: November 30, 2009, 08:50:03 PM »
He could but in doing so he would violate code, its a sub service you can only ground the main service, a sub service must be "bonded" to the main service
I talked to him already so hes good to go
TJ with some stuff
Offline 4PLAYZJ
« Reply #5 on: November 30, 2009, 11:32:43 PM »
Thanks for the info Steve.
