Author Topic: YJ Blower Motor  (Read 2519 times)
Offline Axemanjay
YJ Blower Motor
« on: December 02, 2009, 08:22:37 AM »
Hey Guys...
The blower in the YJ decided it wanted to quit yesterday and it's frikin cold.
I checked all the fuses, metered and good to go.
Is there a inheirant problem with the switch or is the switch serviceable?
92 YJ in its remodeling phase.
Re: YJ Blower Motor
« Reply #1 on: December 02, 2009, 09:08:57 AM »
Is it completely off, or is it only blowing on high?
http://www.billhughes.com/temp/YJblower.pdf
Offline Eagle Jeeper
Re: YJ Blower Motor
« Reply #2 on: December 02, 2009, 10:39:58 AM »
There are resisters that are known to go.  from what i'm told they are easily serviceable.
Re: YJ Blower Motor
« Reply #3 on: December 02, 2009, 11:12:14 AM »
Yes, especially if you have that third joint in your wrist. lol
Offline Axemanjay
Re: YJ Blower Motor
« Reply #4 on: December 02, 2009, 11:31:38 AM »
Completely off.
Offline i_go_commando
Re: YJ Blower Motor
« Reply #5 on: December 02, 2009, 11:42:20 AM »
run a fuse wire right to the motor. if it runs your good till you replace the resitor pack. if the motor dont turn then get a new one or dress realy warm. take the doors off for good measure
Re: YJ Blower Motor
« Reply #6 on: December 02, 2009, 01:44:01 PM »
run a fuse wire right to the motor. if it runs your good till you replace the resitor pack. if the motor dont turn.....
.....then do this:
http://www.4x4wire.com/jeep/tech/interior/cjheater/
Made a world of difference in my old YJ.
Offline Gearhead
Re: YJ Blower Motor
« Reply #7 on: December 02, 2009, 06:51:30 PM »
The old Blazer  heater motor swap , yes  , a great upgrade to 80's YJ's   .  Later YJ's have got a larger heater motor ,  the early motor has a single orange wire , the later motor is a two wire.    If you have a two wire it is the larger heater motor.
Re: YJ Blower Motor
« Reply #8 on: December 02, 2009, 08:03:54 PM »
My YJ was a 95, and I still had to grind the opening to fit the newer blower. Not a lot if I remember, but some.  Gearhead is more than likely correct.  8)
Offline Gearhead
Re: YJ Blower Motor
« Reply #9 on: December 02, 2009, 08:11:17 PM »
My  88  YJ   has the heater motor from a 93  YJ , the opening had to be enlarged to get it to fit .
