Author Topic: d30 pinion nut  (Read 1836 times)
Offline Zombie
  • Jeff the Zombie Jeep
d30 pinion nut
« on: December 02, 2009, 09:23:52 AM »
can this be found at the stealership?
I went to the one by me and they were useless and said that you don't have to replace the nut and no one buys them anyway.
is there a better place to get them?
partsource didn't have them, don't remember if I tried auto value yet.
thanks
steve
Re: d30 pinion nut
« Reply #1 on: December 02, 2009, 09:34:38 AM »
go to DSI the Gear Center on blackfoot (just south of glenmore overpass).  buy a couple, usually a couple bucks each or less.
« Last Edit: December 02, 2009, 09:59:49 AM by FiEND »
Offline Mudhawg
  • Rig Life
Re: d30 pinion nut
« Reply #2 on: December 02, 2009, 09:56:52 AM »
u mean the Gear center Al? cause DSI is off 58th
« Last Edit: December 02, 2009, 10:00:34 AM by Mudhawg »
Re: d30 pinion nut
« Reply #3 on: December 02, 2009, 09:59:23 AM »
yep sorry, im always confused in the mornings..
Re: d30 pinion nut
« Reply #4 on: December 02, 2009, 11:43:03 AM »
DSI is in the SE now, behind the Flying J rest stop.  just off barlow and deerfoot.
google is wrong. call them.
Offline Zombie
Re: d30 pinion nut
« Reply #5 on: December 02, 2009, 11:03:14 PM »
great, I will do.
steve
