Author Topic: winters coming have you guys checked your blinker fluid yet  (Read 4409 times)
Offline .:.Dingman.:.
Re: winters coming have you guys checked your blinker fluid yet
« Reply #1 on: December 02, 2009, 10:44:40 PM »
I tried to do it but I need a metric crescent wrench to undo the cap.  :-\
Dingman
Offline lizard230
« Reply #2 on: December 02, 2009, 10:52:52 PM »
Damn metric crescent wrenches their hard to come by now a days
heres a pic of what i picked up today
http://www.ewanme.net/albums/miscstuff/BlinkerFluid.jpg
« Last Edit: December 02, 2009, 10:57:33 PM by lizard230 »
2000 TJ
« Reply #3 on: December 02, 2009, 10:56:38 PM »
where did you find that? I've been looking all year for it!!!.
That they are I painted it with my can of checkered spray paint, but my buddy borrowed it and my left handed screwdriver and used a bucket of steam to wash it. He needed it to change his muffler bearings  it took two sky hooks to lift his fwd mustang.  ;)
dingman
« Reply #4 on: December 02, 2009, 11:11:17 PM »
My CB has been a bit off lately, I was told that I can fix it by making sure there is enough squelch grease in it. Can anyone tell me where the fitting is and where to get some more grease? Another problem might be that my Jeep is too heavy and its affecting the ground pressure, would removing things from the Jeep fix this?
« Reply #5 on: December 03, 2009, 04:12:09 AM »
No...your problem is that you Jeep is too light. You need to add weight.
As far as squelch grease goes, anyone that is serious about the performance benfits of squelch grease needs a dedicated penumatic grease gun. It MUST be pneumatic, and you must use it ONLY for squelch grease.
« Reply #6 on: December 03, 2009, 07:38:58 AM »
You have too much old air in your tires.
Dingman
Offline Justink
  • '89 comanche 5'' lift, 33's
« Reply #7 on: December 03, 2009, 07:51:25 AM »
i don't think mine has been filled since 1991! should probably go do that..... ;)
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
« Reply #8 on: December 03, 2009, 07:59:21 AM »
BE CAREFUL!!!!
You don't want to mix pre-2003 blinker fluid with post-2003 blinker fluid. If you're going to switch over to the new stuff, make sure that you do a complete system flush with lots of HOT 15W40 before you add the new blinker fluid.
Oh...and add in a friction modifier if you want to smooth out your blink intervals. Just make sure that it's either Teflon based or Bacon based. The lard-based ones smell funny.
« Reply #9 on: December 03, 2009, 09:26:20 AM »
BE CAREFUL!!!!
Olymel FHG+II, or +III?
« Reply #10 on: December 03, 2009, 09:36:19 AM »
You Red Deer guys and your "Olymel this" and "Olymel that".
I tell you, since my friend Ivor told me about the Valbella BSS fluid that he was using in his '84 VW Vanagon, I haven't looked back. If it'll work properly with those German-made Metric blinkers, that's got to tell you something. Every since I started using the Valbella BSS stuff, I've noticed smoother blinker actuation, crisper switch-0ff, and blinker intervals that you could set your watch too. I've even gone to an eighteen month fluid-change interval. Try that with your cut-rate olymel stuff. ???
Offline TJ54
« Reply #11 on: December 03, 2009, 08:39:53 PM »
Dingman
I saw them at princess auto today, 2 for the price  of 1, just ask for help if you can't find them.
« Reply #12 on: December 03, 2009, 09:37:05 PM »
THANKS  TJ!!! I also took out ten pounds of air from each tire to help get better gas mileage.
Dingman
Offline Justink
« Reply #13 on: December 03, 2009, 10:41:53 PM »
One more question but i need to add tranny fouid to my s5 speed and all i can find is ATF.  Does anyone have access to MTF?   :D
« Last Edit: December 04, 2009, 07:15:41 AM by Justink »
« Reply #14 on: December 04, 2009, 07:57:07 AM »
Nope...but I can get you a deal on a banana so that you can lock your rear diff.
