Author Topic: weird rattle 07 jk  (Read 2106 times)
Offline yukonwheeler1
weird rattle 07 jk
« on: December 06, 2009, 06:02:47 PM »
I just had a weird rattle start under my 07 wrangler when I'm in first gear and reverse. It has just started since all this snow has fallen, it has gotten alot louder in the last couple days and it only happens when i let the clutch out.
Re: weird rattle 07 jk
« Reply #1 on: December 06, 2009, 10:45:02 PM »
there was a tsb on the jk's for a clutch disc rattle/noise. we were puttng in the clutch disc from tj's to solve it, with moderate success. could be it.or it could be snow stuck somewhere.
« Reply #2 on: December 07, 2009, 10:43:42 PM »
i thawed the jeep out and i can not hear the rattle anymore so we will just have to see, there was quite abit of snow packed everywhere
« Reply #3 on: December 07, 2009, 11:04:03 PM »
I hope so because i have a long road trip up to the yukon for christmas this month and i don't need any problems for that
Offline sn4cktime
« Reply #4 on: December 09, 2009, 03:54:02 AM »
Hmmm, hasn't happened to mine yet and I've had build-ups of snow/ice/mud in likely every conceivable spot in my jeep.....  Were you letting the clutch out normally or dumping it at the time?
I thought the TSB for "noisy" clutches was for the "chirp" sound some of them were making.  Which mine makes to some degree but I don't care.
« Reply #5 on: December 09, 2009, 06:43:24 PM »
i was letting the clutch out normally
Offline JK2008blckblck
« Reply #6 on: January 21, 2010, 09:05:39 PM »
mine did that because that front u-joint wore out, its not a greasable joint, replaced it and everything is good
2008 jk 2 door
4 inch rough country
37x13.30 ss m-16
procomp rockcrawlers
rcx dual steering stabilizer
1 1/4" rcx body lift
rcx sway bar disco's
bushwacker flares
river raider snorkel
smittybilt front bumer and xrc 8000 winch
PIAA's all over
