Author Topic: Odd mode door operation  (Read 1021 times)
2GRND4U
« on: December 07, 2009, 11:17:37 PM »
96 GC limited ATC. Ok so heat and cold work great but fan blows mostly on floor. When switching between settings I can hear, and can physically see the mode door motor moving its full travel yet only slight air blows out selected setting and mostly blows on floor but it definitly changes a bit. Code 40 comes up wich i know is historic code but thats it. Any idears?
Offline Evil-Jeep
Re: Odd mode door operation
« Reply #1 on: December 08, 2009, 09:26:19 AM »
Not to be a smart arse but - did you ever get mud above the dash, it sounds like the vent is partially plugged. I cleaned a crap load of pine needles, dirt, screws, coins, ect out of my front vents (on a TJ).
« Reply #2 on: December 08, 2009, 08:29:39 PM »
Offline mike s
  • Good times!
« Reply #3 on: December 09, 2009, 10:18:49 AM »
There's a TSB on it for an udate improved door motor.
oldEnuff2NObetter
but still can't help myself
2GRND4U
« Reply #4 on: December 11, 2009, 05:59:12 PM »
Thanks gents!
