Author Topic: RE lower control arm noise  (Read 1889 times)
Offline S-FLY
  • '94 XJ
« on: December 14, 2009, 07:50:22 PM »
I have Rubicon Express lower control arms on my XJ, I feel like they're moving around making clunking noises when I start and stop. I can feel it through the floor.  I couldn't budge the bolts holding them.  Anyone ever experience this?  :o
ve1sly
Offline AV.NINE
Re: RE lower control arm noise
« Reply #1 on: December 14, 2009, 08:10:29 PM »
how are your bushings?
Offline S-FLY
  • '94 XJ
« Reply #2 on: December 14, 2009, 08:12:07 PM »
4 weeks old.
ve1sly
Offline dac
« Reply #3 on: December 14, 2009, 09:18:48 PM »
Sounds kind of like what's going on with mine.  Did it since they were new but all is tight like a tiger.
Offline dubbleJs
« Reply #4 on: December 14, 2009, 09:31:55 PM »
Are they poly/rubber bushings Stan or the spherical ball-joint style ones?
« Reply #5 on: December 14, 2009, 09:40:14 PM »
RE had a problem with a bunch of their rubber/poly bushings, they will replace them when given pictures.
Offline S-FLY
  • '94 XJ
« Reply #6 on: December 14, 2009, 11:49:40 PM »
Rubber bushing.  Is there more where I can read about this RE bushing replacement?
ve1sly
Offline S-FLY
  • '94 XJ
« Reply #7 on: December 14, 2009, 11:52:02 PM »
I'm pretty sure it's these ones, I'll have to crawl under there and double check:
http://www.rubiconexpress.com/Jeep/XJ/Product.aspx?folder=XJCA&part=RE3705
ve1sly
« Reply #8 on: December 17, 2009, 12:39:32 PM »
There is to much weight to move by hand. Either have someone shake the whel and observe movement, or have someone back down an incline in neutral intermitantly slamming the brakes.
If your arms have movement, it will show itself with either of those tests.
Offline S-FLY
  • '94 XJ
« Reply #9 on: December 20, 2009, 08:17:10 PM »
Is there a fix for this?  New bushings (preferably free replacements from RE)?
ve1sly
Offline Pookapotamus
« Reply #10 on: December 21, 2009, 06:45:53 AM »
i get a similar noise in my xj, but i dont have a re lift i have a budjet lift with poly bushings, could my noise be my poly bushings and should i be worried about it?
Offline Justink
  • '89 comanche 5'' lift, 33's
« Reply #11 on: December 21, 2009, 09:01:16 AM »
my lca's did that.  turns out that when i stepped on it or braked hard it moved the front diff enough to hit the lower  control arm resulting in a noise like you are talking about.
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Offline S-FLY
  • '94 XJ
« Reply #12 on: December 23, 2009, 09:19:02 AM »
Oh, so you're saying it could be the end of the lower control arms where it bolts to the axle.  I'll check that.
So is it the bushings or just not tight enough?
ve1sly
