Author Topic: jeep tj fuel pump  (Read 4598 times)
Offline 4Banger_madness
Re: jeep tj fuel pump
« Reply #15 on: December 27, 2009, 02:37:19 PM »
u probably lost and o-ring or seal someplace while cleaning
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #16 on: December 27, 2009, 02:48:19 PM »
probably ran great before the tank was moved  :-X
84 Mustang GT-Built 351W 5spd
Offline esi
« Reply #17 on: December 27, 2009, 03:31:50 PM »
Try this but do it carefully.
If you have an air compressor.
Take blowgun, wrap a rag around the gun and stick it in the filler hole. Add air. the vent will let it out, but you only need about 10 PSI to lift fuel. See if you can get it running that way. You may have got a chunk of crap in a check valve.
Use caution and don't have any open flames near by this will push alot of vapour out of the tank.
« Last Edit: December 27, 2009, 03:33:28 PM by esi »
Formerly of Boots & Boost Inc
Offline 2grand4u
« Reply #18 on: December 27, 2009, 06:39:36 PM »
i'll give that a try but i'm giving jeep stuff a call towmorrow to see if i can get a pump
Offline esi
« Reply #19 on: December 27, 2009, 09:26:45 PM »
Forgot to say you'll need another person.
one to add air to the tank and one to turn the key.
You'll have to keep giving it air to keep pressure in the tank since the vent line will bleed it off
Offline 2grand4u
« Reply #20 on: December 28, 2009, 06:06:22 PM »
got a new pump from jeep stuff and the truck runs great, thxx for any info any of you have provided
Jeep Stuff
« Reply #21 on: December 30, 2009, 04:31:07 PM »
Nice.... so glad to hear its all fixed!  You should of told me you were from the Jeep Assoc and I could have given you the 10% discount.  Next time you need something I will take care of that!
