Author Topic: jeep tj fuel pump  (Read 4596 times)
Offline 2grand4u
jeep tj fuel pump
« on: December 22, 2009, 06:08:22 PM »
so i took out my gas tank from under my jeep and relocated it to the back of my truck to gain a wack of rear ground clerence, i took my fuel pump out so i could clean the filter and tank. i went and put it all back togeter and turn the truck over for ever trying to get gas to the motor, then after it didn`t start i went and pulled the fuel line off the pump to see if the pump was pumping fuel but it`s not so i took it out of the tank and put 12 volt strait to the pump, you can here it pumping but still nothing comes out, WTF.
a new pump is just shy of 600 bux
any one have any ideas i`m stumped and don`t have 600 bux it,s that time of the year
Re: jeep tj fuel pump
« Reply #1 on: December 22, 2009, 06:32:14 PM »
is the pump running in reverse? or is it even possible to reverse the wiring?
pick-up line not in the gas?
now to state the obvious (which you have probably checked).... is there gas in the tank?
Offline 2grand4u
« Reply #2 on: December 22, 2009, 06:37:29 PM »
there is a half tank and i didn`t see any pick up line but the filter is at the bottom in the gas so isn`t that were it picks up or i`m i missing something
« Reply #3 on: December 22, 2009, 06:52:53 PM »
Offline 2grand4u
« Reply #4 on: December 22, 2009, 07:28:25 PM »
the plug only gose in one may so the wires can`t be reversed
« Reply #5 on: December 22, 2009, 07:57:46 PM »
k... hmmmmmm....
is the angle of the tank different from the original angle? Might be sloped away from the pump, thus starving the pump...
Interesting problem Ryan.
Offline 2grand4u
« Reply #6 on: December 22, 2009, 08:08:33 PM »
the tank is half full so i don`t think it could be starved the tank is level, maybe i`ll throw some more gas in it and see what happens.
« Reply #7 on: December 22, 2009, 08:35:19 PM »
why didn't you just put a skid plate over the gas tank and leave it?   or a 2" body lift and lift the tank 2"?  instead did you put it in the rear of the TJ, thus taking away any cargo area you may have had?
pump whirs?  filters good?
pressure in your fuel line?  so you start it and it just cranks over and over again? does it stutter? is it getting any fuel?  is it throwing any codes?  what did you do to clean the tank? the filter?  did you clean the pump?
Offline dac
« Reply #8 on: December 22, 2009, 09:44:25 PM »
I could be wrong on this but when you disconnected the tank the line probably drained (now full of air).  When you turn the key, the pump should presurize the line so to speak, but if it's full of air not much will happen, pump should keep going.
Now for the dumb question.....
Have you tried cranking it with your foot on the pedal to try and bleed the air out   ???
Offline boggincj7
« Reply #9 on: December 22, 2009, 10:21:11 PM »
I think you have to prime the pump. Try disconecting the line after the pump and then try to get it to suck fuel. Once there is fuel in the line you should be good to go. My friend use to have a fuel problem on his injected 4.3 cj5. Sometimes it would lose pressure and that is how he would prime it again. Took him like 5 min. Maybe this will help you.
81 CJ7,304,waggy diffs,SOA,OBA,warn 8274,and always modifying.
Lethbridge Coulee Kruzers
« Reply #10 on: December 23, 2009, 07:05:57 AM »
No prime needed on those pumps. Either check the wiring, or check that you didnt brak a clip on the pump can. If you get the can cock eyed, it will cause the pump lines to seperate.
Offline 2grand4u
« Reply #11 on: December 23, 2009, 04:17:25 PM »
with the fuel line off the top of the pump the pump spins but dosn`t pump fuel out, almost like the impelers are gone. i think the pump is bad, know if the pump is bad can i go to pnp and get a cherokee pump, will it work i just won`t to go wheelin on my holidays so it dosn`t half to be a permant fix.
« Reply #12 on: December 23, 2009, 07:43:05 PM »
Probably not unless you can find a 97 or newer. OBD 2 stuff in TJ's runs 49 PSI, OBD 1 stuff in YJ only runs around 26 if I recall right. Xj's are probably the same.
Did you check the can or not?
Offline comanche killer
  • Aaron
« Reply #13 on: December 24, 2009, 08:54:43 PM »
I seconed this   skid plat and 2" body lift
I told u the same thing when I was there when u told me what u were doing
95 3/4 ton Chev  dailydriver/heavy hauler
97 green MZJ custom 4link rear/3link front, FF 14 bolt rear welded, D 60 front, ax-15, np-231,custom rollcage, half doors, PSC hydro assist 14"kings 40"boggers
Offline 2grand4u
« Reply #14 on: December 25, 2009, 09:02:04 AM »
because body lift are the most ugly thing you can do to a jeep, and i was trying to stay low.  there still lots of room for gear in the back.  and now when i drop in a hole i won't get winded by i huge hit when my tank hits, and it didn't cost me anything to put it back there other then finding out the pump is shot.
