Author Topic: Can they fit??  (Read 2889 times)
Offline marklienhardt
Can they fit??
« on: January 10, 2010, 12:32:47 AM »
I have a 98 TJ with the 3.5 suspension lift.
Can I put the rubicon 275/75/17 inch set on this jeep?
can 16 or 17 inch rims go on here and what size can I do.
Thank you very much
Offline parabs
Re: Can they fit??
« Reply #1 on: January 10, 2010, 08:55:53 AM »
are you talking the 07+ wheels?  If you are, they have a different bolt pattern, however there are wheel spacers made that have adapters for different bolt patterns.
You have (as well as all TJ's) 5x4.5" (in metric 5x114.3mm) and I believe the JK's have 5x5.5"...but dont quote me on that bolt pattern.
-=edit=-
see below, the JK wheels are 5x5 not 5x5.5 like I stated.
« Last Edit: January 10, 2010, 10:31:00 AM by parabs »
2000 TJ Sahara - Sold
Offline WagoneerXJ
  • Bagon Wagon!
Re: Can they fit??
« Reply #2 on: January 10, 2010, 09:45:03 AM »
Parabs is correct, those wheels and tires will not bolt onto your TJ, wrong pattern. However there are lots of aftermarket 16 and 17" rims that will fit your TJ. As fore tire size..33's will fit maybe 35's...MAYBE haha
84 Mustang GT-Built 351W 5spd
Offline jeepers26
Re: Can they fit??
« Reply #3 on: January 10, 2010, 10:15:26 AM »
WJ's are a 5 0n 5 (5 x 127mm) bolt pattern, same as the new JK's
02 Grand Cherokee Overland
6.5" Ironrock Offroad long arm lift (front)
33" Mickey Thompson Baja Claws
Iceland Offroad winch bumper (no winch yet :( )
Iceland Offroad  cut-out fender flares
Garmin GPS
Cobra CB
Offline sn4cktime
Re: Can they fit??
« Reply #4 on: January 13, 2010, 05:36:12 AM »
Yup, JK's are 5x5.
As a note, SpiderTrax makes an adapter for 5x4.5 (97-06 Wranglers) to 5x5 (JK).  $100 a pair.  1-1/4" thick.  Use more Loctite than what comes with them.  Like triple.
« Last Edit: January 13, 2010, 05:40:41 AM by sn4cktime »
Re: Can they fit??
« Reply #5 on: January 13, 2010, 08:03:40 AM »
why do you want to run 17's
Offline MagnutsWJ
Re: Can they fit??
« Reply #6 on: January 13, 2010, 06:42:24 PM »
If you are talking about the JK Rubicon Take-offs, I believe they are 255/75/17, about 32".
'04 WJ - OME HD, 245/75/16 Kumho KL71 MT's, JK wheels, custom rack
Re: Can they fit??
« Reply #7 on: January 13, 2010, 10:45:58 PM »
the jk rims will not fit because of bolt patttern is different   but they do sell spacers that will fix that for you
