Author Topic: 94 grand wandering  (Read 2789 times)
Re: 94 grand wandering
« Reply #15 on: January 23, 2010, 11:06:56 AM »
Did you check the rear end? A loose TB in the back can do that, especially if its lifted and using a drop bracket and an extension bolted onto the diff. May look tight but can shift back an forth causing rear steer. Most people end up welding them on to eliminate any play.
« Last Edit: January 23, 2010, 11:09:09 AM by cLAY »
Offline 4Banger_madness
« Reply #16 on: January 23, 2010, 02:14:08 PM »
thanks for the replies im gunna get new shocks for it this week and weld that bracket in place ill let u guys now if that fixed it.
