Author Topic: 94 grand wandering  (Read 2788 times)
Offline 4Banger_madness
94 grand wandering
« on: January 17, 2010, 11:47:51 AM »
i built a 94 grand for my sister this summer with about 4.5 inch lift we we took it on a huge road trip from red deer through south dacota moad vagas and california and back up to canmore in august with no problems. now she has been driving it since then but in  the last month she has been saying it pulls, so she brought it down and i checked the front end and did a wheel alignment at work. then we tried going into banff for food and i cant keep it in my lane! anyone have anythoughts/ input?
Re: 94 grand wandering
« Reply #1 on: January 17, 2010, 11:58:16 AM »
Is the steering wheel straight? Are all your bushings in the steering good? What lift setup does it have?
« Reply #2 on: January 17, 2010, 12:13:57 PM »
front end is tight    the front has procomp fixed lowers 6" cherokee springs so they sit lower on the grand rear suspension i have rustys adjustable arms both top and bottom and 4.5 " cherokee front springs.   i extended the sway bar links myself and made a rea track bar bracket and drilled a hole for the front one the rear braket is tight as well
« Reply #3 on: January 17, 2010, 05:08:21 PM »
With that many miles on it with bigger tires those wheel bearings should be pretty much toast....
Anything unusual happen to it that could have caused something to get bent? Did you check over the rear end? Any brakes dragging? Who did the alignment? Any DW?
BTW is the shift button on your keyboard broken?
« Reply #4 on: January 17, 2010, 08:10:06 PM »
Hey sorry i dont use capitol letters or periods. i did the alignment and i am a liscenced auto tech i know when stuff is worn out. i only posted because we cant figure it out. and nothing that i know of has happend within the last little bit to cause this
and on the road trip we ran 31" tires not the 33"s
and for winter she has 30" winter tires
nich
Offline mike s
  • Good times!
« Reply #5 on: January 17, 2010, 11:11:56 PM »
Try swapping tires, been fooled by tire pull more than once... They are bad for front track bars too...
oldEnuff2NObetter
but still can't help myself
Offline esi
« Reply #6 on: January 18, 2010, 01:17:18 AM »
Try checking the LCA cam bolts if loose the axle can twist a little and make your steering vague.
Formerly of Boots & Boost Inc
« Reply #7 on: January 18, 2010, 05:21:21 PM »
i rotated tires front to back and everything is tight all bolts and joints
Offline jpthing
  • I like things with wheels.
« Reply #8 on: January 18, 2010, 10:32:11 PM »
Does it pull one way or wander?
What toe in was the align ment done to?
Even if they feel tight I would consider the wheel bearings if they are old.
maybe try fooling around with toe in if everything else checks out. I usually try to get about 1/8" toe in.
good luck
'10 JK unlimited
-Henry Ford
Offline esi
« Reply #9 on: January 18, 2010, 10:59:20 PM »
Check your track bar mount as well to see if there's any movement there. You'll probably need someone to seesaw the steering wheel while you're looking under it, something should show movement.
Hows your steering box?
« Reply #10 on: January 18, 2010, 11:05:15 PM »
nich, if you want i have some good unit bearings i pulled off my ZJ trying to figure out a vibration (ended up being bad tires)
if you want them to swap in to rule out bearings let me know.
also, are you sure something wasn't 'hit' and bent an axle tube or something? thats pretty random for it to start wandering that bad........ specially if everythings tight.
Offline dontask
« Reply #11 on: January 22, 2010, 06:37:40 AM »
I know this is a dumb question  :-X but i dont remember reading in your post.....
Are all the tire pressures the same?
Offline jpthing
« Reply #12 on: January 22, 2010, 09:28:56 AM »
good luck
So does it pull or does it wander?
what toe in are you running?
tell us more
'10 JK unlimited
-Henry Ford
« Reply #13 on: January 22, 2010, 06:43:23 PM »
it doesnt stay in its own lane most times it wants to go right but sometimes it goes left it friggen wierd im thinken maybe the front shocks are a little week the passenger side started making a bit of noise
nich
Offline dac
« Reply #14 on: January 22, 2010, 07:29:36 PM »
Could be shocks, my work truck shocks were worn out.  I knew it too, just had to push the boss hard enough to get them changed out.  It would wander going down the highway.... moreso when it was windy.  New shocks fixed it.
