Author Topic: Damn Front brakes  (Read 877 times)
Offline dac
Damn Front brakes
« on: February 06, 2010, 09:03:58 PM »
So I took a closer look at my front brakes because I knew I had a bit of grease on the inside pad, nothing major.  Turns out the brake material is starting to separate from the backing plates.  Haw bad is it?  It's maybe cracked an inch on the outside pads and 2 or a bit better on the inside ones.
Then I figured I'd take the rotors off just in case I needed to replace the pads.  I'd get them turned but they won't budge.  Is there a trick to getting them off the hubs?  Tried a dead blow and a bit of penitrating oil through the studs but I'm thinking there must be a better trick.
D
Offline jpthing
  • I like things with wheels.
Re: Damn Front brakes
« Reply #1 on: February 06, 2010, 10:13:55 PM »
Strike it with a block of wood n a hammer between the studs.
If that doesn't work lower it carefully onto a block of wood very slightly until it pops.
'10 JK unlimited
-Henry Ford
Offline Crunch
« Reply #2 on: February 06, 2010, 11:04:07 PM »
Dac I had my RH front hub off 3 weeks ago and mine was siezed also I put penantrating oil
on it and used a huge dead blow hammer I have at work-if you like I can bring it over-
you live in the SE don't you? PM me if you like
           Charlie
Offline dac
« Reply #3 on: February 07, 2010, 10:03:41 AM »
Thanks for the offer Charlie.  Got them off this morning using a bfh and a block of wood and a dead blow.
Now to decide which kind of pads to get to help it stop better.
Offline Crunch
« Reply #4 on: February 07, 2010, 10:10:15 AM »
No problem Dwight-good luck with rest of the Job
                           Charlie
