Author Topic: clutch in an AX15 - done, thanks all  (Read 6017 times)
Offline jpthing
  • I like things with wheels.
Re: clutch in an AX15
« Reply #15 on: February 08, 2010, 11:13:36 AM »
not that Jeff is bitter.....
I really wanted to buy that place and make it a sucsessful business, but my wife was not as enthused by the idea...
'10 JK unlimited
-Henry Ford
« Reply #16 on: February 08, 2010, 05:54:55 PM »
used ax-15 with the outer slave cylinder
What did you get this out Eric??  A newer XJ??
yep, from a 1996 cherokee.
the trans jack attachment for a regualr jack is nice. but a regular jack can do it if yer carefull.
be sure to get a clutch aligning tool with clutch kit, will make life much easier.
« Reply #17 on: February 08, 2010, 10:49:10 PM »
so for this swap, do i need a different slave cylinder?  instead of the one that came with my clutch kit?  should i return this kit for another kit?   depending on the donor bellhousing? what should i be looking for?
thanks gents
« Reply #18 on: February 09, 2010, 07:11:31 AM »
thanks gents
Return it and get one for a 93 or newer YJ.  All the bellhousings will be the same for a YJ or XJ
I think the Jeff (gearhead) might actually have what you need
« Reply #19 on: February 13, 2010, 01:47:42 PM »
so, does anyone have a solution to taking out the 4 stripped torx bolts that are holding my skid plate in place?
speak now because i'm about to take the grinder to the whole fawken thing
Offline Waytec
  • not all there
« Reply #20 on: February 13, 2010, 02:31:29 PM »
I would grind them off and them heat the nut and using vise grips work them out.
The obstacle is the path.
« Reply #21 on: February 13, 2010, 02:42:21 PM »
heat them Cherry red also... (not with Propane...it's not hot enough) and use a vice grip on them... I used O2 and MAP gas mix... it heat up to 5400F... 8) It took an O2 sensor out of a 13yo Honda from the East coast like buttah
« Last Edit: February 13, 2010, 02:43:59 PM by SwampSinger »
« Reply #22 on: February 15, 2010, 01:59:10 PM »
so, have tranny out.  pulled slave. it looks fine.  one thing i did notice was the 'reataining' pin or clip/nut thing that should hold the slave onto the input shaft was gone; so the slave was hanging loosely.  that be my problem?  next question is how do i attach the slave again? i've got a new pin and 'retainer' nut (came with clutch kit) should i just use it? how do you pull out the old one? just a pair of pliers i'd presume?
thanks
Re: clutch in an AX15 - finished. thanks all
« Reply #23 on: February 20, 2010, 05:19:08 PM »
to update. put her all back together today and she's running sweet.  still need to put the floor/doors etc. back together but she's running sweet.
thanks for all the tips!
Offline Sean778
Re: clutch in an AX15 - done, thanks all
« Reply #24 on: February 20, 2010, 06:37:03 PM »
Congrats buddy, glad to hear you got that task all buttoned up!  :)  You'll be on the trail again in no time.  Now all you need to do is come up here and crack the whip on me so I finish putting my crap back together.  The tires are being mounted & balanced this weekend though, so I guess that sort-of counts, although it's not me turning any wrenches . . .
Are there any further modifications/repairs in the works for your YJ?
'89 XJ
« Reply #25 on: February 20, 2010, 08:26:52 PM »
YJ should be G2G. still need the SYE for the rear to get rid of that tcase drop, but she's good to go right now. haha
we'll get your heep runnin soon.
Offline Duncan71
« Reply #26 on: February 21, 2010, 05:57:36 AM »
I'd slowly start sourcing out the parts to convert to an external slave.  I did a slave in august of 08 and was doing it again in feb 09.  The price difference if you can get deals on parts is also not much....  see if you can grab a junked ax15 on here so you have the bellhousing and such.
