Author Topic: rear main...  (Read 1874 times)
Offline yyc_tbird_sc
rear main...
« on: February 17, 2010, 11:47:40 PM »
Just wondering what you guys think. I'm working on putting a new clutch into my ranger, and after a few days of being down I thought I was going to be able to get it done tonight. WRONG!!! I was given the wrong clutch master cylinder....so I just started replacing seals and everything else that needed to be done.
When I opened up the rear main seal box, I noticed that it was a speedy-sleeve version. I'm not a big fan of these things, and there is no real need for it as there is not enough wear on the crank to warrant it. What do you think? Should I just use it, and not think about it? I've never used one before, how is the sleeve secured to the crank, just RTV?
Offline jpthing
  • I like things with wheels.
Re: rear main...
« Reply #1 on: February 18, 2010, 09:39:54 AM »
I wouldn't use the sleeve if it's not needed. I'm pretty sure brand-name speedi sleeves generally use the same seal as without the sleeve but some of the other similar products are thicker and use a special seal with a lager opening. Generally they are just an interferance fit.
'10 JK unlimited
-Henry Ford
Re: rear main...
« Reply #2 on: February 18, 2010, 11:18:49 AM »
find the proper seal. speedy sleeves are used for one thing only, and thats for grooved or damaged sealing surfaces.
Re: rear main...
« Reply #3 on: February 18, 2010, 06:08:00 PM »
Kinda what I thought...like I said, there was not obvious signs of wear on the crank. I took it back today, and a new one should be in my hands tomorrow. Kind of a squirt off as the truck has been on stands since Sunday evening for a clutch job....oh well, it looks like saturday should be a good day to work in the garage....
