Author Topic: Rear Wiper and automatic transmission handle  (Read 1035 times)
Offline Matt4x4
« on: February 21, 2010, 04:44:51 PM »
I think my rear wiper lost the pivot hole for spring, how do I take it off to replace it?
How do I get the plastic handle off the automatic transmission lever on a Cherokee '90?
Re: Rear Wiper and automatic transmission handle
« Reply #1 on: February 21, 2010, 06:13:28 PM »
No idea what you mean on the rear wiper.
For the t handle on the tranny, pull it down into 1-2 then give the handle a good yank and it will pop off. A REALLY good yank may be needed.
Offline apeman
  • not as grumpy
« Reply #2 on: February 21, 2010, 07:18:51 PM »
there should be a retainer clip behind the wiper arm itself...small screwdriver works followed by a good yank....same ith your trans shifter..small clip at the base of the handle...shift into 1-2 and you will see it (if equipped)..small screwdriver will pry it out....also apply belt dressing once both items are replaced...to avoid squeal.
Getting grumpier every day.
« Reply #3 on: February 21, 2010, 07:55:14 PM »
On my '89 there was no clip on the T handle, just pulled hard....
Offline apeman
  • not as grumpy
« Reply #4 on: February 21, 2010, 11:59:52 PM »
hmm..my 90 had one...either way...yank it hard enough and it will come off...clip or not!
1988 Cherokee
« Reply #5 on: February 23, 2010, 11:23:51 AM »
The rear wiper has a spring clip that when you squish it with needle nose pliers it will come out.
Then you have to yank on it to get it out, just be sure it is inline.
The handle comes off by yanking it inline in the 1 or 2 position.
« Last Edit: February 24, 2010, 03:22:15 PM by 1988 Cherokee »
