Author Topic: dana 35/44 drum brakes  (Read 2322 times)
Offline Pookapotamus
« on: February 23, 2010, 06:52:45 AM »
before i took my 92 xj off the road i had completly rebuilt the rear brakes on my dana 35, new drums, shoes, spring kit and cylinders. now my 95 xj has a 44 in the rear, will all my new brakes fit on to the 44?
i have been searching the net to find an answer but have not found anything yet. trying naxja.org as well but i figured some one on here might know.
Re: dana 35/44 drum brakes
« Reply #1 on: February 23, 2010, 07:49:43 AM »
They should fit. Only time I've seen what look to be a larger drum is on the odd grand.
If you holf the drums up to eachother you will find out for sure.
« Reply #2 on: February 23, 2010, 08:20:01 AM »
thanks billy, i will have to give it a try when i get the 95 back in the garage. i will post and let you know if they do fit.
« Reply #3 on: February 23, 2010, 08:42:47 AM »
don't quote me Dana, but i would wager discs from an 8.8 (exploder rear axle) would bolt right up too......... they are a direct swap from an ZJD35;  its possible they'd fit too.
check that www.naxja.org site..... good info there for things like this!
« Reply #4 on: February 23, 2010, 08:48:41 AM »
i want to go dics but for now Mrs. Pook has me on a budjet.  :'(
Offline jpthing
  • I like things with wheels.
« Reply #5 on: February 23, 2010, 09:34:21 AM »
My Xj dana 44 has much larger drums than my Xj dana 35.
the 35 is a '95 and the 44 is from a '89.
'10 JK unlimited
-Henry Ford
Offline mike s
  • Good times!
« Reply #6 on: February 24, 2010, 07:48:19 AM »
rockauto.com has a pretty good online catalog for crossing up part numbers.
oldEnuff2NObetter
but still can't help myself
Offline dubbleJs
« Reply #7 on: February 24, 2010, 03:26:52 PM »
Agreed. d44 drums are noticably larger than d35 drums.
Offline Tyn Pow
« Reply #8 on: February 24, 2010, 04:34:53 PM »
Slight hijack but I am wondering the same except with the C8.25 and the D44, can one bolt onto the other?
Offline jpthing
« Reply #9 on: February 25, 2010, 09:06:00 AM »
The drums? I don't think so...
'10 JK unlimited
-Henry Ford
« Reply #10 on: February 25, 2010, 09:11:52 AM »
if they are different just change backing plates. not really an issue either way.
FTR 8.8  plates dont fit for disk swaps. 93 and up zjs, 03 rubi's, and 04-06 d35 and 44's all swap onto those old xj axles.
beware of commanche 44's. they have an oddball back plate pattern.
« Reply #11 on: February 25, 2010, 03:09:12 PM »
As long as its not a mj44, the back plate patterns are the same
