Author Topic: 2000 TJ seems to govern out at 3000 rpm  (Read 1775 times)
Offline Mudpig97
« on: March 06, 2010, 05:37:33 PM »
drives ok till 3000rpm then "governs out"?   Let off throttle till tach is under 3 and its ok again.  Any ideas?  My kid said it used to do that at 5000rpm( Y hes running that high I don't know) now its down to 3000.
85 CJ7, toy axles and 35's, miller locker in rear.
Re: 2000 TJ seems to govern out at 3000 rpm
« Reply #1 on: March 07, 2010, 04:34:08 PM »
ive seen plugged cat. cons. that can do this. pretty much the engine will run and idle fine, even rev up well with no load. but once there is a load on the engine it just bogs down and is gutless at mid to upper rpms.  last i saw this problem on was a viper. nothing worse then road testing a viper and getting passed by a mini-van.
« Reply #2 on: March 07, 2010, 07:14:53 PM »
only time i saw this was with a bad connection to the speedo at the transfer case.  my speedo would bounce around and max revs were limited to 3000.  so it could be considered a limp mode.
« Reply #3 on: March 07, 2010, 07:36:15 PM »
Plugged cat is the most common. Specially on TJ's
Offline Mudpig97
« Reply #4 on: March 11, 2010, 10:41:48 PM »
Its got no cat/con.  Figured it out, trailjammmer chip is screwed.  Pulled the chip, runs fine stock.
« Reply #5 on: March 15, 2010, 03:44:42 PM »
i dont mean to be an arse, but next time you have a tech question you might want to mention that your engine has a chip. that would help much. glad you found the problem. now ditch the chip and add a turbo...  ;)
