Author Topic: Help on picking a MJ lift Kit  (Read 1146 times)
Offline Layback209
« on: March 10, 2010, 10:32:12 AM »
So I've been researching lift kits i would like to purchase for my 91 4.0L MJ, dana 30-35, short box, running Cooper STT 31"s on TJ rims. And i have narrowed it down to 3 bolt and go kits (maybe looking for opinions).  My truck is my DD for the time being so after the lift it needs to be comfortable and very streetable + up offroad capabilities.   I would like to lift in the 3.5" - 5.5" to give better bumper clearance for  jeeping through dips, and getting my front skid plate a bit higher of the ground so it doesn't turn into a plow when hitting the deeper stick clay mud.  I would also like to drop a dana 44 in and regear (after lifting when some more $$ acume).  Here are the lifts i'm considering.
5" Front and Rear (standard lift with CAD)
http://www.rocky-road.com/comanche.html
http://www.rocky-road.com/xjcad.html
Add on options:
Long Shocks
T-Case Drop
Pitman Drop
quick disks
Adgustable LCD's
RE 5.5
http://www.national4wdonline.com/cart.php?target=product&product_id=3288&category_id=363
Anyone running this bad boy? I was also thinking of getting the RE3.5" super flex kit and comboing it with some custom rear leaf spring to match lift?
4.5" Motion Offroad Lift Kit
http://motionoffroad.com/catalog/index.php?main_page=product_info&products_id=208
Any Recommendations, opinions, experience with these lifts would be greatly appreciated.
Regards,
D
Offline stroker sahara
Re: Help on picking a MJ lift Kit
« Reply #1 on: March 10, 2010, 10:23:55 PM »
I too was in the same boat you are in 1.5 years ago. I ended up going SOA rear, 4.5 RE coils with 2" spacers in front, RE superFlex adjustable UCA's and LCA's, and 32 x 11.5 STT's. I went way over my budget, but it was worth every penny. Here is a pic of the truck:
PM sent.
Offline Waytec
  • not all there
« Reply #2 on: March 10, 2010, 11:00:00 PM »
Give Bear a call at Bear Trax 4x4 Outfitters he has a Re 5.5 that he is looking to get ride of for a relay good deal.
Bear - 780.651.1621
The obstacle is the path.
Offline Layback209
« Reply #3 on: March 11, 2010, 08:15:21 AM »
Wow that MJ is awsome and its super clean!! Prefect lift height. Did you have any issues with the rear slip yoke after you went SOA?  Those STTs are a great tire too, to bad you can't get them any more.
Thanks Waytech I'll give bear a call...
Offline comanche killer
  • Aaron
« Reply #4 on: March 11, 2010, 05:51:13 PM »
check thes guy out bout a lift for my ZJ a year ago and love it beefy control arms
http://rustysoffroad.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=rustys&Category_Code=S
95 3/4 ton Chev  dailydriver/heavy hauler
97 green MZJ custom 4link rear/3link front, FF 14 bolt rear welded, D 60 front, ax-15, np-231,custom rollcage, half doors, PSC hydro assist 14"kings 40"boggers
« Reply #5 on: March 11, 2010, 06:14:56 PM »
I didn't have any issues. I used a Ford Explorer 8.8 which moved the pinion yoke +/- 1" forward. I didn't install a t-case drop kit either which lots of guys do. As for the STT's, they are still listed on their website. I will have to check with a buddy that is a Cooper dealer to confirm tho. I had 2 different sets and was extremely happy with them.
