Author Topic: CJA plumbers or anybody with a drain snake?  (Read 2261 times)
Offline JENSSEN
    • Racing For The Cure
« on: March 11, 2010, 11:46:23 PM »
I have a clogged clothes washer floor drain, everything drains AOK except the section of pipe that relieves the washing machine.
Help?
www.racingforthecure.ca
Offline yyc_tbird_sc
Re: CJA plumbers or anybody with a drain snake?
« Reply #1 on: March 12, 2010, 09:11:45 AM »
Last time I needed one, I just rented it from Home Depot....it was only like $8 or something
Offline JENSSEN
« Reply #2 on: March 12, 2010, 10:57:58 AM »
THANKS!
Offline Sean778
« Reply #3 on: March 15, 2010, 09:05:18 AM »
Hmm, I have a similar problem with my bathroom sink.  I never considered renting the tool, thanks for the good advice.
'89 XJ
« Reply #4 on: March 15, 2010, 12:09:42 PM »
You can probably buy a snake for $25.00 or so then you have one in your arsenal.
Offline JENSSEN
« Reply #5 on: March 15, 2010, 01:03:48 PM »
As the drain line in Question was a 4" pipe with no access hole to snake it, I rented a 2" Power snake 25' ($45.00/4Hr) from Home depot. I made a larger cutter for it and fit it through the pee trap to start working ion the drain. After 4 runs the blockage was removed and I can do laundry again. I did look into purchase but only the small drain snakes (toilets, sinks) we feasible cost wise of buy VS Rent. I also hit it with Acid 2-3 times after to make sure it won't plug up any time soon.
Jenssen 1 VS Drain 0
Offline Sean778
« Reply #6 on: March 15, 2010, 01:18:13 PM »
Want to come to Edmonton and fix mine next? ;)  Only kidding, well done sir.
'89 XJ
Offline JENSSEN
« Reply #7 on: March 15, 2010, 02:10:51 PM »
Check your sink pee trap,.. the U portion of the pipe below the drain in the sink, you may have an access plug in the bottom that allows you to easily clean the areas that clog.
-J
Offline Sean778
« Reply #8 on: March 15, 2010, 02:35:57 PM »
Good advice, unfortunately I just replaced that section along with the rest of the sink hardware, and it didn't solve my problem.  I'm thinking the blockage is a little further down the line.
'89 XJ
Offline JENSSEN
« Reply #9 on: March 15, 2010, 03:00:43 PM »
Try sulfuric acid,.. You can buy it at home Depot $5.00 just dont get it on the sink or chrome,.. use a funnel
Offline Sean778
« Reply #10 on: March 15, 2010, 03:03:36 PM »
Mmm, delicious H2SO4.  Sounds good, I'll give that a try, I've got some spare time this evening.
'89 XJ
