Author Topic: what to do  (Read 2453 times)
what to do
« on: March 15, 2010, 08:35:36 PM »
alright boys and girls
need some advice ..
i need to do gears and bearings in both front and rear diffs
as well as front and rear axles
now my question is i dont have the 1800$ to do it all in one shot
i figure i should do front and rear gears and bearings and front shafts   leave the rear ones for a month or so
or do i suck it up and do them all at once and be tight as BEEP for a month or so
Offline dac
Re: what to do
« Reply #1 on: March 15, 2010, 09:03:55 PM »
I'd either wait till after the next big snow dump or do it all at once.  I'm betting we get one last city stopper before we see spring.
Re: what to do
« Reply #2 on: March 15, 2010, 09:14:46 PM »
a month isnt very long. wait the 1 month, then order it all at once. save on shipping or whatever and then you can organize the install time better. instead of taking it all apart twice.
Re: what to do
« Reply #3 on: March 15, 2010, 10:10:47 PM »
install will be done by my brother
i just dont knwo how much damage im doing in the rear end everything sounds loose and well i know im changing everything out but is there any chance of busting my locker in there or what
Offline Mikes off road
Re: what to do
« Reply #4 on: March 17, 2010, 07:40:30 AM »
Sorry to hijack the post but I have a question about gears. I had my gears done about 8 months ago and now I want to install a detriot locker in the rear. Do you think I would have to redo the Backlash or screw around with the Pinion setting at all. I know I should have waited and done them both at the same time but I didn't.
Offline X-Treme
Re: what to do
« Reply #5 on: March 17, 2010, 12:53:07 PM »
Yes.
Re: what to do
« Reply #6 on: March 17, 2010, 01:26:29 PM »
No Mike, you only have to do the backlash, and carrier bearing preload. Pinion will remain the same.
Not a tough job. Specially if its a 8.25 with the spanners.
Re: what to do
« Reply #7 on: March 17, 2010, 01:31:32 PM »
There is a good chance your locker is gone already. Unforunate as that sounds, of all the rubicon diffs I've done, which is probably 50 plus, the only two I've ever seen with internal failures have been blown lockers.
You might want to look at that before making a decision. If your locker is blown you will be getting into 2000$ just repair and replace whats in there. Specially if the locker guts have chewed the gears up.
Offline Eagle Jeeper
Re: what to do
« Reply #8 on: March 17, 2010, 04:35:40 PM »
Do it all at once one way or the other  I am not a big fan of being broke so I'd wait a month.  Don't know about the locker but if there is bits of metal floating around in your diff fluid I can't imagine its doing the locker any good
