Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Terminal on passenger side below coil.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Terminal on passenger side below coil. (Read 856 times)
canfourjeep
Budget Lift
on:
March 16, 2010, 09:34:08 AM »
There is a block on the passenger side of my 99 TJ engine. This has ground wires from the battery and two other wires going into the wiring harness. It is a metal block with 2 terminals.The block bolts to the engine and then the wires bolt to the terminals. Any ideas what this is?
Logged
dac
That CB Yapper
Re: Terminal on passenger side below coil.
Reply #1 on:
March 16, 2010, 10:20:14 AM »
ground, if you mess with it I'd be betting things won't work right. Make sure it's clean and has a good connection.
It should be the return from the battery and fuse box and body to the alternator through the engine.
Logged
This is not 'Nam, this is wheeling. There are rules.
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
