Author Topic: Bump stops  (Read 1147 times)
Offline midnightcowboy
Bump stops
« on: March 18, 2010, 09:32:07 PM »
What did some of you guys doing after lifting your CJs or YJs? After 7-8" lift Im trying to figure out how to properly set up my stops so I dont tear fenders off.
Offline Eagle Jeeper
Re: Bump stops
« Reply #1 on: March 19, 2010, 12:22:29 AM »
As a cheap fix I am planning on taking some 2" square tubing  and building a drop bracket for the existing bump stop and welding it to the under side of the frame. Something like this \_/  but with probably 45 deg. angles.   Thats the extent of my computer drafting abilities a shameless use of slashes and an underscore.
Offline Knox
Re: Bump stops
« Reply #2 on: March 19, 2010, 12:50:10 PM »
someday I'd like to model the Full Jeep...
2003 TJ
Re: Bump stops
« Reply #3 on: March 19, 2010, 01:19:39 PM »
What eagle said. Square stock to space the stockers down from the frame. I also use 1/2" conveyor belt for the fine tuning.
Re: Bump stops
« Reply #4 on: March 19, 2010, 03:59:53 PM »
What did you draw that up with its exactly what I was thinking.
Offline yyc_tbird_sc
Re: Bump stops
« Reply #5 on: March 19, 2010, 05:18:28 PM »
If you want an easy CAD program.....check out Google SketchUp. It's FREE and all the tutorials are online in video format, and it's pretty straight forward to use...here's the drawing I did of a trailer I'd like to build this spring/summer....
Re: Bump stops
« Reply #6 on: March 19, 2010, 08:26:26 PM »
Thank you very much the download has begun
Offline Knox
Re: Bump stops
« Reply #7 on: March 19, 2010, 08:39:36 PM »
Google sketchup has some pretty cool features, and it is definitely a lot easier to learn than a full parametric modeling package.
but yeah the program I used was Pro/ENGINEER
2003 TJ
Offline Pookapotamus
Re: Bump stops
« Reply #8 on: March 19, 2010, 09:20:00 PM »
i use autocad an autodesk inventor, with inventor i can even calculate the stress on the peices that i design!  8)
