Author Topic: T-case Leak  (Read 783 times)
prelude48
T-case Leak
« on: March 19, 2010, 08:27:51 PM »
I have a 98 cherokee witha 242 transfer case, i noticed today it stated leaking, When i looked to see where it was coming
from, it was a small hole on the left side of the shift linkage. Almost looks like there should be a plug or cap there or something.
Is anyone familiar with this? i can post a pic if need be
Thanks guys! :)
Re: T-case Leak
« Reply #1 on: March 19, 2010, 10:53:49 PM »
Just to the left of the black tab there is a hole to access a roll pin for disassemble. It should have a rubber plug in it. You could try a glob RTV sealant but I'm not sure it would stay.
prelude48
Re: T-case Leak
« Reply #2 on: March 19, 2010, 11:34:11 PM »
Sweet deal!  Thanks
Re: T-case Leak
« Reply #3 on: March 19, 2010, 11:43:32 PM »
that is one shiny transfer case Clay!
Re: T-case Leak
« Reply #4 on: March 20, 2010, 09:24:00 AM »
Yes unfortunatly it did not last long. Its a 242 that was swapped into my ZJ but I tried to reuse the the 249 shift gate and linkages. I didn't get it setup quite right and ended stripping out some syncros and ended up with no 4wd in low range.  >:(
Swapped in a 231 instead but its not all shiny.....
