Author Topic: dana 30 axle seal tool?  (Read 4305 times)
Offline mike s
  • Good times!
« on: March 23, 2010, 02:13:31 PM »
Sigh going to have to tackle axle seals on my front diff, but i read they are a b#tch to do without special tool #*******, any idea who might have one? Also would consider spare front axle to build then swap complete....
oldEnuff2NObetter
but still can't help myself
Re: dana 30 axle seal tool?
« Reply #1 on: March 23, 2010, 02:25:42 PM »
they are easy.  screw driver to pry them out then large socket and hammer to tap new ones in.
Offline Pookapotamus
« Reply #2 on: March 23, 2010, 02:38:50 PM »
or pick up a set of the fancy greasable seals for the dana 30 like dom has
« Reply #3 on: March 23, 2010, 02:42:01 PM »
that's outer seals, still need inner seals
« Reply #4 on: March 23, 2010, 02:42:58 PM »
ah ic well get both!
Offline mike s
  • Good times!
« Reply #5 on: March 23, 2010, 03:22:33 PM »
Ya pretty sure it's inboard seals, i have the tube seals (like Dom) but have the two piece RH axle w/vacuum disconnect.
oldEnuff2NObetter
« Reply #6 on: March 23, 2010, 03:27:34 PM »
The inner seal should not be a problem, but you have to remove the vacuum actuator to access the passenger side seal.
Offline apeman
  • not as grumpy
« Reply #7 on: March 24, 2010, 03:21:27 PM »
Quote
yep....small hammer though, not the 5lb deadblow. ;D ;D
Getting grumpier every day.
« Reply #8 on: March 24, 2010, 03:35:47 PM »
Stop talking bad about me  :P
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #9 on: March 24, 2010, 04:12:27 PM »
I haven't done it yet, but I need to and plan to use this method:
http://www.bc4x4.com/tech/2006/dana30-seal-installer/
Home made tool
98 TJ 4" lift + goodies
Offline Layback209
« Reply #10 on: March 25, 2010, 12:39:33 PM »
I would recommend, using several 1/2 socket extensions snapped together (can get some really big one from p-auto dirt cheep) with a large socket on one end (can remember the size I used).  For the passenger side seal (assuming vac engaging model) you tap the seal into the engagement fork housing.
For the drivers side seal you tap the seal into the diff pumpkin. Installation is the reverse.  I would not push the thread rod technique its a pain in the butt!
Regards,
Offline mike s
  • Good times!
« Reply #11 on: March 25, 2010, 08:16:03 PM »
figured i could hobble something together, chrysler show this fancy seal tool, thought i might get one if there was intrest...
oldEnuff2NObetter
Offline starcreekyj
« Reply #12 on: March 25, 2010, 10:24:20 PM »
I have installed a couple of seals using a length of threaded rod, a plate the size of the seal and a plate for the outer end of the axle.
Put the seal in place slide the threaded rod through the axle and seal put the plate on the rod then a nut. Put a plate on the outer end of the rod with a nut and start tightening making sure the seal doesn't tip.
Long winded but I hope I explained it well enough.
Lethbridge Coulee Kruzer
93 YJ With Mods
« Reply #13 on: March 25, 2010, 10:28:00 PM »
that is a hell of an idea starcreek!
« Reply #14 on: March 25, 2010, 10:31:35 PM »
tried this on a Dodge D44. it was a PITA.  it kept going in crooked;  one good whack on a socket and it set the seal much easier.
the CAD one is beotch..........  if you're gonna pull that seal, might as well grab some one piece axles out of a tJ/XJ and put in the correct seal for this upgrade.................
