Author Topic: TJ Door Removal  (Read 1000 times)
BigCam
TJ Door Removal
« on: March 23, 2010, 04:14:38 PM »
Hi all,
This is the beginning of my first summer in Alberta as well as my first summer with a Jeep.
Bought a silver 2000 TJ last September, picked up a soft top cheap off Kijiji over the winter - and since today is an absolutely gorgeous day I had the bright idea to take the doors off and go for a spin...
However, I'm having trouble getting the doors off - I'm also having trouble finding a wrench that fits the nut on there.  Have tried 8mm, 10mm, 1/4 inch etc.
Does anyone have any pointers/ideas?  Any suggestions would be quite welcome!
Cheers,
Cam
« Last Edit: March 23, 2010, 04:16:31 PM by BigCam »
Re: TJ Door Removal
« Reply #1 on: March 23, 2010, 05:01:41 PM »
Well, I had to cut off one bolt because it was stripped.
I used a metric wrench. Vise grips work too.
Use a jack-all to get them out of the hinges and the some white lithium grease on the hinges for next time
Offline Evil-Jeep
Re: TJ Door Removal
« Reply #2 on: March 23, 2010, 10:31:14 PM »
start soaking them in some sort of penetrating oil..... I sprayed mine twice a day for about two weeks before they both finally came loose.
just watch the threads they are a bit soft and will will mash easily
Re: TJ Door Removal
« Reply #3 on: March 24, 2010, 08:35:03 AM »
mine were tough the first time, i just lifted from the bottom and kept swinging the doors open and closed and they came up shortly before i died.
