Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Unit Bearing Bolts?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Unit Bearing Bolts? (Read 992 times)
Brooneg
Budget Lift
Unit Bearing Bolts?
on:
April 05, 2010, 07:52:30 PM »
I buggered up my brand new unit bearing on my 93 ZJ on Saturday's breakin run
Does anyone have the 3 bolts handy that I can grab? And maybe a rotor for the driver side as well
And a rim like this maybe??? The rim is buggered up too
Last Edit: April 05, 2010, 08:02:49 PM by Brooneg
Logged
Pookapotamus
Talks waaay too much!
Re: Unit Bearing Bolts?
Reply #1 on:
April 05, 2010, 08:03:52 PM »
mike is looking for the three bolts that hold the unit bearing to the knuckle, the lug bolts came loose and bounced around inside the rotor and mushroomed the heads on all three of his bolts. and as you can see took out his rotor as well.
Logged
Brooneg
Budget Lift
Reply #2 on:
April 05, 2010, 08:05:22 PM »
Yeah!! what my Mechanically inclined friends says. I am just the gumby who breaks stuff
Logged
FiEND
Wrecking Ball
Reply #3 on:
April 05, 2010, 08:12:14 PM »
you missread break-in as breaking
that rotor and rim look totally useable.
pick n pull prob has everything you need.
Logged
JackstandJohnny
where Jeeps go to die
Reply #4 on:
April 05, 2010, 08:12:45 PM »
nuts.
hit up PNP mike, just yank them out of the first jeep you see; if you look around i bet you will find a jeep with the hubs taken off and the bolts just lying around. i know this happens cause i've done that..........
Logged
~ rescue green JKUR on 35s. typical rubicon build
cLAY
Reply #5 on:
April 05, 2010, 08:14:08 PM »
Check the depth of the hat on the new rotor. There have been some changes over the years in some of the aftermarket stuff and I've got stuck withthe wrong rotor before.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Unit Bearing Bolts?
