Author Topic: specs of ubolts for the 8.25?  (Read 3127 times)
Offline Zombie
  • Jeff the Zombie Jeep
« on: April 06, 2010, 05:05:28 PM »
I am putting in new springs in the rear of the jeep and need new U bolts, anyone know the specs of the u bolts???
thread size, diameter of axel, how far apart the bolts need to be(end of the U) and how long the stock ones started out at???
I can look under the jeep, I  just don't have the caliper to measure the axel and stuff like that handy.
thanks
steve
Oh, it is a 97 cherokee  auto, 4.0 L if that helps
Re: specs of ubolts for the 8.25?
« Reply #1 on: April 06, 2010, 10:02:26 PM »
they should be 1/2" bolt and I think a 3" diameter.  Standens or any other suspension shop should be able to tell you want you need
Offline XJHERO
  • Soberphobic
« Reply #2 on: April 06, 2010, 10:09:58 PM »
just take one off go to standens tell them you want one x-amount longer than this one and they will bend them on the spot to your spec.
on sat they are only open till 12:00pm IIR
DD
Get at me Wolf
Offline Zombie
« Reply #3 on: April 06, 2010, 10:55:12 PM »
I went there and they said they could not give me any specs and to find out the exact specs for them
could be a liability thing
I think I will just take one off and head there in the car and have a few made up
just hope they are not too expensive
Offline jpthing
  • I like things with wheels.
« Reply #4 on: April 06, 2010, 11:07:20 PM »
I have had them make several sets from a simple drawing. Just draw a picture and go under and measure as many dimensions as possible. They're pretty helpful and friendly over at standen's eh? ::)
'10 JK unlimited
-Henry Ford
Offline Zombie
« Reply #5 on: April 06, 2010, 11:21:59 PM »
I don't know about everyone of them, the one "helping" me was grumpy and not very nice at all.
but some of the other guys looked like they were nice and helpful.
I think the remove and take in and ask for a longer one is what I end up doing.
with luck thursday night or friday morning will be removing the bolt and head over friday.
any chance you still have the shims Boone?
once I figure out what I have, I think I will know what I am going to need to get the rear axle lined up properly.
« Reply #6 on: April 07, 2010, 12:42:34 AM »
Does it have red tape on the Front bumper? That XJ looks very familiar.
Measure your parts to make sure, simple measuring tape should confirm the following.
According to a book...8.25 Ubolts should be;
 Thread size x width x length Dimensions
1/2"-20 x 3.250" x 6.75"
 8.25 diff tube should be 3"
If your tube is only 2.75" let me know. I have a spare set of procomp ubolt & hardware kit for beer   ;D  & I'm probably closer then standens
Offline Zombie
« Reply #7 on: April 07, 2010, 10:11:14 PM »
I don't think so, but it does have the ARB logo on it.
I am in the NE alot. I live in taradale and work at the NE Costco.
I didn't even think to check the book, haynes manual right?
thanks and I will have a look at that.
cheers
steve
Offline jpthing
« Reply #8 on: April 12, 2010, 10:01:54 AM »
4 degree shims are sold, 6 degree still available.
'10 JK unlimited
-Henry Ford
