Author Topic: Lifting the hood for cooling  (Read 2471 times)
Offline Waytec
  • not all there
« on: April 07, 2010, 11:38:16 AM »
So the summer is coming and I need to do something about the 4.0 in my XJ getting hot.
I was thinking about cutting and putting Run Cool vents in, but I have seen guys putting spacers on the hood hinges and lifting it. How well does this work? And how thick of spacers are you using?
I am liking this idea because I can lower it back down for the winter.
The obstacle is the path.
Re: Lifting the hood for cooling
« Reply #1 on: April 07, 2010, 12:25:20 PM »
Just get one of these instead, http://www.extremeradiator.com/store/ProductDetail.aspx?sku=1193-3 and no more cooling problems
Offline Waytec
  • not all there
« Reply #2 on: April 07, 2010, 12:42:44 PM »
I have actually never had a overheating issue.
Just in the summer the hood and panels get so hot you cannot touch them. Once you open the hood you can feel the heat trapped in the engine compartment and it is a little excusive.
« Reply #3 on: April 07, 2010, 12:46:20 PM »
sounds like you need some fancy hood louvres.
couple snips and your good to go
Offline The Machinist
  • I’m with stupid!
« Reply #4 on: April 07, 2010, 01:13:33 PM »
I'm gonna try some purple ice this summer.
« Reply #5 on: April 07, 2010, 02:25:48 PM »
Put shutters on the louvres/vents like on the forced-air heat ducts in a house...
Ghetto Fab!
Offline yyc_tbird_sc
« Reply #6 on: April 07, 2010, 02:32:37 PM »
Speed Holes!! LOL
1988 Cherokee
« Reply #7 on: April 07, 2010, 02:59:49 PM »
Mine was overheating today because of idling.
Overheated a little towing the trailer back to Calgary a month ago.
Just going to put in a better thermostat and replace the fluids and see what happens.
If it still is overheating I will just cut the hood open.
Then get a cored truck radiator from the junk yard.
« Reply #8 on: April 07, 2010, 03:24:58 PM »
http://greatlakesxj.activeboard.com/index.spark?forumID=43793&p=3&topicID=6594654
or vents
http://www.comancheclub.com/forums/viewtopic.php?f=2&t=7131
or
Buy a spare hood from one of the several Cherokees floating around or being parted out.  Cut out a cowl, and weld it to the main hood.  You can make it as wide as you like.  No need for vents, and no issues with rain or water coming through.
« Last Edit: April 07, 2010, 04:02:10 PM by dunl »
« Reply #9 on: April 07, 2010, 04:14:03 PM »
it's the square headlights.  not very aerodynamic.  cut squares in big enough to use as windows like that bolivian video you posted
« Reply #10 on: April 07, 2010, 05:21:26 PM »
I've heard of XJ guys removing the weather seal from the trailing edge of the hood to allow the hot air to escape.
One minute job and reversible if you don't like it.
Vince
Offline jpthing
  • I like things with wheels.
« Reply #11 on: April 14, 2010, 09:16:51 PM »
I have foundf that even removing the hood entirely didn't make a big difference.
"water wetter" and a new fan did though!
'10 JK unlimited
-Henry Ford
« Reply #12 on: April 14, 2010, 10:11:05 PM »
When I was in Moab I ran with out the hood and it definatly made a difference. Tried water wetter twice, both times on tow rigs. and never saw a difference.
