Author Topic: Is my steering stabilizer shot?  (Read 1337 times)
Pangloss
« on: April 07, 2010, 03:35:22 PM »
Hey folks - this is my first post here.
Headed out to Flathead River this morning and had to turn around when a bit of rough pavement gave my '09 JK a bad case of the front end wobblies. I was driving over moderate potholes and patches, on an easy curve doing about 70km/h. Front end started a slight bounce and the steering wheel was trying to turn left and right. Gentle braking took care of it. It happened again on straight pavement, again over a moderately rough patch, this time going a little slower, maybe 60km/h.
- nothing looks broken or feels loose
- fluid levels are fine
- tires are properly inflated
- it felt exactly the same as high speed wobbles on a motorcycle (one without a steering dampener)
Is it my steering stabilizer? Here's a link to some images of aftermarket stabilizers: http://www.tellico4x4.com/index.php/cPath/459_442
I would love to fix this myself for under $200, rather than giving a garage a bag o' cash.
Thanks in advance.
Re: Is my steering stabilizer shot?
« Reply #1 on: April 07, 2010, 03:40:15 PM »
09? is that not under warranty?
is the jeep lifted?
sounds like death wobble.
Pangloss
« Reply #2 on: April 07, 2010, 04:37:55 PM »
Yeah, it's still under warranty, but if it's less than a couple of hundred I'd rather fix it myself. Plus aftermarket stabilizers seem a lot better than OEM.
« Reply #3 on: April 08, 2010, 07:46:42 AM »
Get it fixed under warranty, there could be a much more expensive issue at hand.  Steering stabilizers ONLY mask issues
« Reply #4 on: April 08, 2010, 08:43:59 AM »
take the steering stabilizer off and go for a drive.  then you will know if it is working or not.
