Author Topic: can add a leafs replace broken leafs?  (Read 1381 times)
« on: April 09, 2010, 02:40:46 PM »
actually this would be for the Dodge. rear leaf is broken;  could i take out the broken leaf and use an add a leaf?
(i would do this to each side)
just wondering......
Re: can add a leafs replace broken leafs?
« Reply #1 on: April 09, 2010, 02:56:00 PM »
Swap in a new rear axle with coil spring conversion, run 36's.
Offline thayer03
« Reply #2 on: April 09, 2010, 03:46:23 PM »
If you pull the spring pack and take it to standens I'm sure it wouldnt cost much for them to just replace the broken leaf.  I used to work in the shop there.
FSJ's RULE!!!
« Reply #3 on: April 09, 2010, 09:04:26 PM »
As long as its not the main leaf I don't see why not. However if you've broken one leak the rest probably aren't in the best of shape. I second  talking to Standens.
Offline Waytec
  • not all there
« Reply #4 on: April 09, 2010, 11:31:04 PM »
Do you want the mechanic answer or the farmer answer?
The obstacle is the path.
Offline XJHERO
  • Soberphobic
« Reply #5 on: April 09, 2010, 11:39:34 PM »
did you mean an answer from a mechanic who paid someone to set up his gears or from a automotive one??
 ;D
« Last Edit: April 10, 2010, 12:07:47 AM by XJHERO »
DD
Get at me Wolf
Offline Waytec
  • not all there
« Reply #6 on: April 09, 2010, 11:58:24 PM »
It is funny I turn wrenches all day and on the weekend I don't want to do it, anyways paying someone and I keep my sanity is worth every penny.
 The Heavy Equipment Mechanic answer is take it to a spring shop and have them replace the broken one or call wreckers and find a replacement.
Suspension I remember that from school. FYI the ride suspension in a D11 is in the seat.
