Author Topic: damaged trackbar bracket on axle.  (Read 1487 times)
Offline Zombie
  • Jeff the Zombie Jeep
« on: April 13, 2010, 09:39:25 PM »
So I discovered that I have stretched out the hole on the axle that the track-bar bolts to on to.
I now need to have this repaired somehow.
who should I see about this?
hopefully I can support a CJA guys shop or something like that, or just a good shop that you would recommend that would be able to repair it for me.
I would assume it would entail some welding or something like that. but I do not have the skills to do this right now.
thanks,
Steve
Re: damaged trackbar bracket on axle.
« Reply #1 on: April 13, 2010, 09:43:56 PM »
Talk Jay (LemonAid Jay) at Chanda Motors.  He can do the welding for you.
« Reply #2 on: April 13, 2010, 09:47:44 PM »
Yip, fill in ovaled hole, then have him weld washers on the bracket so it doesn't happen again.
Offline Zombie
« Reply #3 on: April 14, 2010, 12:01:40 AM »
sweet.
I will drop him a line tomorrow I think.
thanks
steve
Offline Mikes off road
« Reply #4 on: April 14, 2010, 06:35:40 AM »
On my old Xj I was able to weld a thick washer over the worn out hole. Seemed to work till I swapped Jeeps.
« Reply #5 on: April 14, 2010, 09:24:36 AM »
You can do a washer if you have to, but a small (1/2") sleeve of tube welded to the end of the bracket is a better fix.
Washers are relatively soft, and at best are usually a temporary fix. If you use tube, it wont wallow. More work, but worth the effort.
