Author Topic: Drive train play  (Read 1516 times)
sgo70
Drive train play
« on: January 19, 2006, 03:06:04 PM »
OK I realize this could be a broad topic, I'm just looking for ideas were to start. I have a 2001 TJ, 4 inch lift, 33's, SYE kit, CV driveshaft. I put the SYE kit and D/S in at the same time so I can't tell if it was one or the other.
 When I'm starting out, or accelerating in the lower gears,as well as gearing down, I have a small clunk. It feels like something in the rear axle but I cant be sure cause no one will lay under there to listen while I drive. I took the D/S off to see if I could feel any play in the T/C, or rear pinion but no luck. Is it normal to have play in the CV D/S, although I never thought to check that while it was off.
 ANY IDEAS???????
blackrube
Drive train play
« Reply #1 on: January 19, 2006, 08:56:55 PM »
had that,,,  tighten up your rear lower control arms ,,,see if that helps
Offline RckyMtnTJ
    • http://www3.telus.net/lck
Drive train play
« Reply #2 on: January 19, 2006, 09:43:52 PM »
When I have had a clunk in that situation, its been either loose control arms or crappy Teraflex Control arm bushings.  I would check them tings out!!
98 TJ 4" lift + goodies
sgo70
Drive train play
« Reply #3 on: January 20, 2006, 01:46:30 PM »
Thanks, I'll go see......Rubicon lift though....
sgo70
Drive train play
« Reply #4 on: January 21, 2006, 12:50:52 AM »
...you guys are friggen' genious.....thanks I would have never thought of that....
