Author Topic: 4lo problems on tj  (Read 1317 times)
bgill
4lo problems on tj
« on: January 30, 2006, 11:26:29 PM »
anybody have any problems with their four lo. I have an 03 rubicon with 6 inch full traction long arm lift and 1 inch body and my 4 lo keeps slipping out. Seems like the handle to put it in four lo cannot go back far enough to fully engage the 4 lo.
RedYJ
4lo problems on tj
« Reply #1 on: January 31, 2006, 01:54:49 AM »
Check the linkage between the T-case and the shifter, maybe since the body lift it has moved the linkage and changed the angles that it works with.
Offline GiS
4lo problems on tj
« Reply #2 on: January 31, 2006, 08:24:58 AM »
A) Trim your console and tub
B) Get the AA shifter relocation bracket that relocates the shifter to a hard mount on the T-case.
4lo problems on tj
« Reply #3 on: January 31, 2006, 11:32:45 AM »
Quote from: "GiS"
Yep, shifter.
Theres a good skyjacker one that works as well. But you might find it just needs adjustment, try that first.
Your body lift should have come with a plate that corrects the shift linkage position.
