Author Topic: Wire through the Fire wall  (Read 1596 times)
Offline Tagg
« on: April 28, 2010, 01:23:17 PM »
I need to put a hole for wires through the fire wall on my JK. Is there a preferred spot to put the hole?
08 Rubicon
Offline Evil-Jeep
Re: Wire through the Fire wall
« Reply #1 on: April 28, 2010, 04:20:10 PM »
How big of a hole? and what are you running thru to the cab?
Offline yyc_tbird_sc
« Reply #2 on: April 28, 2010, 05:00:04 PM »
For some reason, I can see someone posting the pic from a couple years ago when one of the members got a branch through the firewall....
Use a step-bit, and a good one at that. Drill the smallest hole possible, and then be sure to de-burr it when you're done. Use a quality grommet, and some good RTV. I don't think that there is one location that is better than another, but judge for yourself where you can access with a drill.
« Reply #3 on: April 28, 2010, 05:20:31 PM »
You don't need to put a hole in your firewall.
On your JK there is already a spot that you can slide a wire through with  coathanger and some patience.
It's in the top right corner of the compartment. Pull out the plastic molding on the far right side of the dash, and you will see a little hole there full of expanded foam insulation. You can poke a coat hanger through to the engine compartment underneath the hood cowl. Tape your wire to it, and pull it on back...and Bob's your uncle.
Offline Tagg
« Reply #4 on: April 28, 2010, 10:05:56 PM »
So facing the steering wheel, up and to the right of the gas pedal?
08 Rubicon
« Reply #5 on: April 29, 2010, 07:52:30 AM »
Nope. Extreme top right corner of the entire dash. It comes out into the top of the cowling around the engine compartment, on the passenger side. Just behind and above where the battery is located.
It's pretty fiddly to do, so you need to be patient, but you don't have to drill anything, and the foam that's already in there as sound deadening seems to do a good job of keeping things quiet and draft-free.
Offline Tagg
« Reply #6 on: April 29, 2010, 01:39:35 PM »
That's what I was affraid you were giong to say!  I just put in dual battery tray and I think that wall is packed solid.  I'll have a look tonight but it is really crammed in there.  I need to get a wire through to the lighter to get the "key" power for the battery relay.  There is a wire stuffed through on the driver's side where Modern put through the line for the HID light relay.  I was just thinking it would be better to put the extra stuff through separately and "properly".  Anyway I'll have a look tonight when I get home.
08 Rubicon
« Reply #7 on: April 29, 2010, 03:15:36 PM »
Shouldn't be a problem. It doesn't come through the firewall right by the battery, it is further back and out to the passenger side.
You will have to fold your hood all the way back and rest it on the windsheild to get reasonable access.
Offline Tagg
« Reply #8 on: April 30, 2010, 12:14:04 PM »
Gotcha!  Slow but I see where you mean now.  Thanks
08 Rubicon
