Author Topic: van raised roof removal  (Read 1416 times)
Offline Matt4x4
« on: May 06, 2010, 03:48:09 PM »
Are the van raised roof hard to get off, is a cutting tool needed.
Offline jkrubi
Re: van raised roof removal
« Reply #1 on: May 07, 2010, 07:13:24 AM »
Depends on the make. Usually they are bolted down and glued on if I rember correctly.   It's been a long time since I took one off.  A cut off saw would work really good but you will still have to seperate it from the old roof then. If times a factor cut it off and deal with it later.  Then you also get all the misc bits that go with it.
Offline Evil-Jeep
« Reply #2 on: May 07, 2010, 09:22:01 AM »
The underground parking lot at chinook mall should have some nice spots to remove your roof!
« Reply #3 on: May 07, 2010, 09:44:07 AM »
noooo they make great float boats when removed
Offline Matt4x4
« Reply #4 on: May 07, 2010, 10:23:41 AM »
Thanks man, just picked up a boogie van off of Kijiji and will get the roof at the junk yard and doing the job in their parking lot. To many rentacops at chinook. hahahaha
