Author Topic: NEED SOME HELP  (Read 1118 times)
Offline padler
NEED SOME HELP
« on: May 11, 2010, 10:27:19 AM »
whats better for cooling the motor.
water only
or a mixture of coolent water
Offline Pookapotamus
Re: NEED SOME HELP
« Reply #1 on: May 11, 2010, 10:32:26 AM »
coolant and water! antifreeze help to keep the water from freezing but it also raises the boiling point of water so that the water in your block does not boil then build up pressure which opens the psv on your radiator cap releasing all your coolant. it also has anti corosion chemicals in it so that the water does not corrode your block. go get your self a coolant tester from napa for $5 and make sure you have the proper mixture, usually about 50/50.
Offline fug
  • Airdrie Pick n Pull
Re: NEED SOME HELP
« Reply #2 on: May 11, 2010, 10:50:48 AM »
What the Pook said!
Fug
TJ Rubicon
Re: NEED SOME HELP
« Reply #3 on: May 11, 2010, 09:38:08 PM »
But....... pure water does absorb/release heat better than most other liquids out there.... just food for thought. 50/50 is a good ratio.
Offline parabs
Re: NEED SOME HELP
« Reply #4 on: May 11, 2010, 10:09:07 PM »
redline water wetter works good at keeping the engine cooler, but only use as an additive to your existing 50/50 mix.  Also, only use distilled water...You can get 4l of Distilled water at Shoppers for like 3$.  Redline water wetter is available at canadian tire.
2000 TJ Sahara - Sold
Offline Evil-Jeep
Re: NEED SOME HELP
« Reply #5 on: May 12, 2010, 09:28:45 AM »
Beer works in a pinch.... but the smell from the cleanout isn't very nice.
Re: NEED SOME HELP
« Reply #6 on: May 12, 2010, 12:50:09 PM »
Anitfreeze also contains anti-rust properties. Putting straight water in to get you home is ok but over the long term will cause internal rust problems.
