Author Topic: Clunk clunk clunk  (Read 1118 times)
Offline Justink
  • '89 comanche 5'' lift, 33's
Clunk clunk clunk
« on: May 19, 2010, 07:21:20 PM »
So I think my tranny mount has excessive play.  Whenever I step on it (Forward or back) I get a really loud clunk.  The tranny is tight to the motor and the crossmember is tight too.  Any ideas or am I on the right track here?
'91 cherokee AX15 4.5'' lift 3/4'' transfercase drop
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Re: Clunk clunk clunk
« Reply #1 on: May 19, 2010, 08:55:29 PM »
3 clunks or lots of clunks?  whatabout coasting?  what about when you downshift?
Offline Justink
« Reply #2 on: May 19, 2010, 09:31:11 PM »
Little clunk when downshifting, none while coasting.  Clunk has gotten worse since I have gottwn the Jeep
« Reply #3 on: May 19, 2010, 09:37:32 PM »
mine did it and was the driveshaft / ujoints.  cant really tell until you remove the driveshafts.
take the front shaft off and see if it still makes the noise.  if it does, put it back on and remove the back one and see if it makes the noise.  then you can check the ujoints at the same time.  only takes an hour to do all this.
Offline Justink
« Reply #4 on: May 19, 2010, 10:18:05 PM »
 Only issue is we've done all u joints front & rear within 500 kms. I had the front shaft pulled and clunk did not go away, will pull rear shaft this weekend.  If I pull the rear shaft won't I have a t case fluid leak?
Offline Justink
« Reply #5 on: May 22, 2010, 05:33:25 PM »
BUMP!!
Offline esi
« Reply #6 on: May 22, 2010, 08:51:29 PM »
LCA bushings. Or I had a clunk that came from a motor mount that was humped.
Formerly of Boots & Boost Inc
Offline Justink
« Reply #7 on: May 22, 2010, 10:23:18 PM »
LCA bushings are good, control arms out on under 300 km's good ago, and bushings were good.  I will check the motor mounts.  Am I way off on the transmission mount idea?
