Author Topic: What did you do to your Jeep this week  (Read 4328 times)
devildogg
« on: May 24, 2010, 04:53:58 PM »
Took it fishing
Played in the snow
Gave it a little extra pull
« Last Edit: May 24, 2010, 05:00:55 PM by devildogg »
Offline Aspirated
Re: What did you do to your Jeep this week
« Reply #1 on: May 24, 2010, 05:02:46 PM »
killed the starter
         decided i needed to rig an electric fan
1998 XJ
2008 KK
Offline .:.Dingman.:.
« Reply #2 on: May 24, 2010, 08:12:37 PM »
Fixed the saggy bum, the diesel got a nice chip/dent from some kids with a sling shot.  >:(
Dingman
Offline JENSSEN
    • Racing For The Cure
« Reply #3 on: May 24, 2010, 10:05:40 PM »
Which one?  The big one? The DD? The neighbors kid? The ZJ that went to a friend? Just about herpes out but still have a s#it ton to get done. At least the garage is clean , the little one is out and the big one is in,...
www.racingforthecure.ca
Offline Knox
« Reply #4 on: May 25, 2010, 07:10:22 PM »
took the hard top off and put the soft top on :)
2003 TJ
Offline Justink
  • '89 comanche 5'' lift, 33's
« Reply #5 on: May 25, 2010, 09:35:53 PM »
Drove it, Temporarily sold the "Significant other" one.
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Offline Marco
« Reply #6 on: May 27, 2010, 08:01:28 PM »
Well im up at work so I just Pretended I was driving it with the top off in the sun.
locked and loaded
« Reply #7 on: May 28, 2010, 09:03:25 AM »
i  yelled at mine a little bit........... doesn't fix stuff apparently.
Offline JENSSEN
« Reply #8 on: May 28, 2010, 09:13:15 AM »
I tried that too! No luck here either and apparently neither does drinking a beer and staring at it,..
This week still assembling the last bits on the 93 2 DR, and the big Jeep got a new to it header panel and fender as I adjusted the old parts with a culvert at HRC,...  Next Radius arm replacement, more tube protection,....
Uggggh maybe I will try the Beer technique again,.. maybe I was doing it wrong
« Reply #9 on: May 28, 2010, 09:14:45 AM »
beer works!
hey, did you still want some 1500 Ram leafs Jenssen?  i should have em out tonight.....
Offline JENSSEN
« Reply #10 on: May 28, 2010, 09:52:03 AM »
Sure I would like to stick them under the XJ to see how it would stand,.. I am working with the guys on Pirate on the leaf Spring TOM info
Offline dac
« Reply #11 on: May 28, 2010, 10:02:27 AM »
I put the kids car seat back in it (as designed without towel) and took my son to Home Depot.  Extremely exciting run, nothing broke and it still sounds as healthy as the last time I had it out.  Even was able to give the wipers a test to make sure they still worked.
YoungFluff03TJ
« Reply #12 on: May 28, 2010, 11:42:40 AM »
Discovered a bent axle....after my wheel flew off while driving which destroyed my brand new rim (less then 90 km on it)...so i put an axle into it and purchased another rim. then i also stared at my jeep (like this  >:() and had a beer. also cleaned a lil bit of mud from the inside. the rain/snow took care of the outside and deposited it on my driveway, which ran into the street and is now in front of the neighbors driveway. mua ha ha
Offline Raspberry
« Reply #13 on: May 28, 2010, 10:15:07 PM »
I sank mine into a 3-foot mudhole. Killed my high-amp alternator, to which I have lost the warranty card. Engine also sounds sick... there's mud everywhere outside and inside the jeep, who knows what's up with the engine... maybe more mud? ha, wouldn't put it past me :)
Offline XJHERO
  • Soberphobic
« Reply #14 on: May 28, 2010, 10:50:00 PM »
and did you learn anything from this??
DD
Get at me Wolf
