Author Topic: I got a new vibe...  (Read 1635 times)
I got a new vibe...
« on: May 27, 2010, 05:34:46 PM »
I've got a new vibration coming through steering wheel and gas pedal.  I would describe it as harmonic because the vibration is so fast.  It makes my hands tingle when driving. mmmm tingle....
It started after Fish East...  ::)
Drivers side wheel bearing was shot (second time in 6 months and under warranty).  Passanger side still feels good so I didn't change it. Rear drive shaft also went and has been redone.  Vibration happens even when the front drive shaft is out. I've run it a week with out the front shaft in.  I rotated the tires and that helped somewhat.
I start to feel it between 40 and 70 kmh during acceleration.
What should I check next?  I did a quick check of the ball joints on the drivers side and didn't feel anything but then again, I don't know what a bad ball joint feels like...
Thx
Offline esi
Re: I got a new vibe...
« Reply #1 on: May 27, 2010, 06:02:05 PM »
try a tire balance check. Possible swap tires with someone else for a test drive.
Formerly of Boots & Boost Inc
« Reply #2 on: May 28, 2010, 09:02:46 AM »
sounds like your jeeps mad at you kevin; better wheel it tomorrow some more ;)
i would guesstimate a tire issue too....... you are runnin trxus afterall ;)
sunday if its worse come by and we can swap over my 35s if you want; get a second set of meats on the jeep see if it goes away........
« Reply #3 on: May 28, 2010, 12:26:17 PM »
coolio
« Reply #4 on: May 30, 2010, 04:36:34 PM »
Problem solved.  Just need to get rid of those fantastic Truxus tires.    ::)
For sale:  four 35's; 60% wear that cause nasty vibrations.
Offline BlackAura
  • 2003 TJ Rubicon (Stock)
« Reply #5 on: May 30, 2010, 07:08:20 PM »
ohhh, no price = free right? ;)
BlackAura (Kevin)
« Reply #6 on: May 31, 2010, 01:25:08 AM »
Think tire swings for the kids
« Reply #7 on: May 31, 2010, 09:49:44 AM »
My favorite tires. :):)
Give me a shout if you are looking for some Toyo's Kev.
Otherwise, Noel strongly recommends the MTR Kevlar. ;)
« Reply #8 on: May 31, 2010, 09:57:09 AM »
Will do Bill.  And yes - Toyo's are the plan...
« Reply #9 on: May 31, 2010, 10:16:25 AM »
maybe you should look at some pro comp MTs Kevin;)  they seem to love your jeep!! hahahaha
« Reply #10 on: May 31, 2010, 10:24:15 AM »
Just let me know when you start parting out the YJ buddy  ;)
« Reply #11 on: June 01, 2010, 02:30:34 AM »
I was patiently waiting for the "TOYO PIMP" to chime in.  TA-DAA! I knew you couldn't resist taking a knock at those Trxus(redheaded half-brother of the Thornturd)tires.
You can't go wrong with the Open Country's Kev, but be different. Give some consideration to the Goodyear Mt-R Kevlars . Robin loaned a set to his brother-in-law last weekend. He was pleased with them.
