Author Topic: squealing clutch??  (Read 826 times)
Offline M T
squealing clutch??
« on: May 28, 2010, 12:31:54 AM »
So after a few puddles and hill climbs on Tuesday, my Jeep started to make a loud squealing sound while driving on the trails.  It sounded just like a drive belt, but it wasn't.  Instead, the noise instantly stopped as soon as I started to push my clutch pedal in.  Then I would let the pedal out and the squealing would start again?  I believe I have a noisy throw-out bearing at the best of times, but I want to know what this sound is and what I should do?  The squealing only happened twice while we were out on Tuesday and lasted for abot 5 minutes each time.
2004 TJ Sport RME
31" Goodyear MT/R's
Offline JENSSEN
    • Racing For The Cure
Re: squealing clutch??
« Reply #1 on: May 28, 2010, 08:19:32 AM »
Sounds like a diiiirty throw-out bearing.
www.racingforthecure.ca
Offline M T
« Reply #2 on: May 28, 2010, 08:44:52 AM »
And how serious is this?  And the remedy??
2004 TJ Sport RME
31" Goodyear MT/R's
Offline Evil-Jeep
« Reply #3 on: May 28, 2010, 05:56:11 PM »
Did you remove the drive belt and test for noise..... I had a bit of oil on mine, and it would only squeal when wet, but would stop at low RPM and when I was shifting gears. before you get into more costly repairs, take 2mins pull of the belt and see if you can get the same squeal.
Hmmm, Wet and squealing.....
Offline JENSSEN
« Reply #4 on: May 28, 2010, 06:11:06 PM »
Pull the inspection cover and give it a quick shot of white lithium, worked on my turbocoupes
