Author Topic: XJ differential?  (Read 2750 times)
Offline spongymuffin
XJ differential?
« on: June 02, 2010, 03:17:14 PM »
im trying to find a new diff for my 98 XJ will one from a grande Cherokee work?
Re: XJ differential?
« Reply #1 on: June 02, 2010, 03:18:35 PM »
yes for the front
no for the rear
just saw you meant rear
« Last Edit: June 03, 2010, 12:02:53 PM by JOhnnyC »
« Reply #2 on: June 02, 2010, 03:21:30 PM »
Will i need the hole axle or can i just take the gears?
Offline fug
  • Airdrie Pick n Pull
« Reply #3 on: June 02, 2010, 03:25:06 PM »
To clarify... it will work but you'll need to weld spring perches on so its not bolt in.
I wouldn't recommend swaping used gears from one axle to another.  Used gears or new.. you still need to setup them up and since thats 80% of the cost and effort... why not just get new.
Fug
TJ Rubicon
« Reply #4 on: June 02, 2010, 03:30:35 PM »
or grab an intact xj diff from pick n pull for less than $100
« Reply #5 on: June 02, 2010, 03:33:16 PM »
Thanks all. fiend ive been trying i can never find one in the right year.
« Reply #6 on: June 02, 2010, 04:00:08 PM »
doesn't have to be the right year.  there might be things to look for to ensure the same gear ratio and axle disconnect or not.. but almost all are the same
« Reply #7 on: June 02, 2010, 04:19:00 PM »
Front or rear dude?
for the rear
Take the hole axle. It's simpler.  rear from a 97 to 99...  You'll have  the the 29 spline Chrysler 8.25 in the rear... make sure you take it from an XJ that has the same tranny then yours (auto or Manual).. they have different gear ratio. Look for the diff tag
that way it will be all bolt on.
 Grand C. have coils in the rear...
Offline esi
« Reply #8 on: June 03, 2010, 12:40:06 AM »
I have a rear diff. Complete from drum to drum with E-brake cables. 3.55 gears I think. Was told it had 135k when pulled
$50            From a 96
Formerly of Boots & Boost Inc
Offline JENSSEN
    • Racing For The Cure
« Reply #9 on: June 03, 2010, 09:11:33 AM »
Dave @ Affordable Autowreckers has 4 or 5 97-01 Xj's and He is very fair price wise. You can tell him I told you to call him it may help you with a deal I dunno but He treats me VERY well.
Affordable Auto Wrecking
Dave Lumsden
5620 94th Ave SE
403.236.8116
1.800.247.9364
www.racingforthecure.ca
« Reply #10 on: June 03, 2010, 10:57:15 AM »
Quote
I called them yesterday, they did'ent have anything...
Offline JENSSEN
« Reply #11 on: June 03, 2010, 06:51:25 PM »
Wrong ratio? They have at least 4 at least they did on Saturday
