Author Topic: Machine shop recommendations  (Read 1685 times)
Offline Grease Nipple
« on: June 07, 2010, 09:17:29 PM »
Almost have the heads off the dodge, Can anyone recommend a good, but fairly inexpensive machine shop to have the heads tested for cracks and warpage? maybe even have them cleaned up a bit?
how much would this typically run? I'm on a tight budget.
Thanks in advance!!
Ian
Re: Machine shop recommendations
« Reply #1 on: June 07, 2010, 10:36:16 PM »
i know a guy........................
Offline stroker sahara
« Reply #2 on: June 07, 2010, 10:39:44 PM »
You may want to check with Cetus Automotive as their machine shop was blowing old inventory out the door cheap. I believe they wer $50 per head and I think they are rebuilt. They may have Dodge heads still.
« Reply #3 on: June 08, 2010, 07:48:00 AM »
I talked to them. They didn't have any 360 heads left.
Offline fug
  • Airdrie Pick n Pull
« Reply #4 on: June 08, 2010, 07:56:50 AM »
Eeek not Cetus... have not heard good things about them
Try Precise ... they are supposed to be decent
Fug
TJ Rubicon
« Reply #5 on: June 08, 2010, 09:42:17 AM »
PM on here The Machinist.
He owns his own shop doing head work and has done a couple jobs for me(a Cummins diesel and a subaru). Good work, good price.
« Reply #6 on: June 09, 2010, 09:49:59 PM »
Just got back from Jamie's AKA The Machinist...
Great guy!!
Thanks Jamie!
unfortunately the heads are toast and I need to find a engine now :(
