Author Topic: Pitman arm nut/washer size?  (Read 1270 times)
Offline Rodzilla
« on: June 08, 2010, 04:39:57 PM »
I purchased a new steering box and when I gave them my old one for the core charge they also got my pitman arm with it since I couldn't remove it (to lazy was more like it), and since I bought a new drop pitman arm I really didn't care. But now my problem is finding a new bolt/washer that will work. Does anyone know the grade/thread/size of nut and where to find it and a hardened washer? Thanks in advance for any input. Cheers
« Last Edit: June 08, 2010, 04:41:51 PM by Rodzilla »
Re: Pitman arm nut/washer size?
« Reply #1 on: June 08, 2010, 05:42:11 PM »
google says 1 - 5/16"
you need breaker bar for sure and some penetrating oil would help.  take them to pick n pull and you can even get spares.
Offline Rodzilla
« Reply #2 on: June 08, 2010, 06:57:14 PM »
Actually I'm looking for what the bolt size is on the pitman arm. Like what thread count is and if its course/fine and the diameter of it. Was going to see if I can find a nut to match at a bolt supply store. Is there a washer? I can't remember. Thanks.
« Reply #3 on: June 09, 2010, 09:54:29 AM »
Big ol lock washer on there.
Caliper the shaft on your box for the size, and its definately fine thread. Pretty sure its around 7/8's, but you had best check to make sure.
Offline Rodzilla
« Reply #4 on: June 09, 2010, 11:15:24 AM »
Yes ^^^^^^^ its a 7/8 14 pitch(fine) thread. Going to go find one now  :)
Offline jpthing
  • I like things with wheels.
« Reply #5 on: June 12, 2010, 10:46:44 AM »
I would be reluctant to use anything but the correct factory part or something that was very high quality. I would get one pff any jeep at PNP.
A word to the wise:`anytime you remove the pitman arm, check the tourque on the nut once and a while for a few weeks.  My buddy`s jeep loosened up when set with a torque wrench to the correct tourqe, I usually tighten mine more or less as tight as I can get it, use blue threadlock and check it for a few weeks.
This is not something you want coming off while you`re driving!!
'10 JK unlimited
-Henry Ford
Offline Rodzilla
« Reply #6 on: June 13, 2010, 07:57:29 PM »
I'm using a grade 8 nut and washer. I will check the torque periodically like you suggest. I trailer my rig to and from the bush, no hi-speeds to worry about stuff coming off. Probably lucky if I've seen of 30km/hr yet.
