Author Topic: Transmission noise  (Read 806 times)
Offline Rubiclone
Transmission noise
« on: June 15, 2010, 08:55:05 PM »
Ok, so.
In my trani, between 1st and 2nd. It makes a strange noise when the gear is either engaged or semi engaged ( like when I'm downshifting ) I never hear it in any other gear.
It seems to be getting worse and no one can figure it out. It sounds like someone grinding coffee but in the bathroom.  :o
If anyone can help I would really appreciate it.....as I have no desire to spend another chunk of money for someone to say "sorry ma'am I couldn't find anything.....That's 400 please" I am hoping someone has had this issue. The jeep was bought used, and it appeared to have been run on a trail.
 I already had to replace the clutch. And it has only 65k on it and he's a 2005 with a 6spd.
Cheers
Lose yourself in nature, and find yourself at home.
05 TJ,  RE 3.5" super flex lift with a 3" body lift, 33's on pro comp wheels, LP8500 super winch sitting on a smittybilt XRC stinger bumper , cat back exhaust. And some mud on my dash
Offline OffRoadNewbie
  • I Blame Keith !!
Re: Transmission noise
« Reply #1 on: June 15, 2010, 09:00:12 PM »
i have grinding between 1-2 as well it gets a little better once its warmed up a bit bin the same for the last six months on mine im sure its the Synchro so i ll just put up with it for awhile
2006 TJ its Green !! ;)
Offline Rubiclone
« Reply #2 on: June 15, 2010, 09:06:45 PM »
Naw.
Mine has just gotten louder over time...never goes away even when warm. It worries me
« Reply #3 on: June 15, 2010, 10:43:12 PM »
does sound like a synchro is going..... has the tranny fluid been changed/flushed recently?  what does the tranny fluid look like?  if if hasn't' been done since you've owned it, do it.  might have water in it or something like that anythings possible
jeeps make noises. just remember, when they STOP, then you have to start worrying...........................  means whatever was makin the noise has kicked the bucket.
something to keep in mind, if ur gonna wheel, learn to change fluids;   cause its easier to change them 3x a year than blow a tranny/tcase/diff................
Offline Rubiclone
« Reply #4 on: June 16, 2010, 12:58:28 PM »
I am getting modern to dump the fluid when they put in the suspension lift.
If it is a syncro, is that a big job  :-\ makes me nervous just hearing that.........
