Author Topic: Soft Top Woes  (Read 857 times)
Offline BlackAura
  • 2003 TJ Rubicon (Stock)
Soft Top Woes
« on: June 16, 2010, 09:44:54 PM »
So I thought I had sourced most of the missing parts that I needed for my soft top, but it turns out (after checking out http://www.jeep4x4center.com/mopar/jeep-wrangler-tj/softtop-hardware.htm) I'm missing a lot more.
What I have:
- Door surrounds / frames (manage to source the hand screws that mount them to the roll cage)
- Rear window, tailgate bar and screws for mounting it.
- I've sourced the rear side windows, picking them up sometime this week
- Tailgate clips
- Roll bar bracket / clip things that the frame snaps into.
- Soft top, and I'm talking just the canvas.
Missing:
- the whole metal piping frame (which is actually a couple different pieces)
- the front latches
- other misc parts?
As per pictures:
- Rear Window + Tailgate Bar
- Door Surrounds
- Soft Top
Is it worth me trying to source the other parts, or should I just look into one of the whole best top kits that comes with all the hardware?
Edit:  Considering the safari top, wrap around windjammer, and deck cover....but I think some of that requires you to have parts of the original soft top hardware, I'm not sure.
« Last Edit: June 16, 2010, 09:48:12 PM by BlackAura »
BlackAura (Kevin)
Offline jpthing
  • I like things with wheels.
Re: Soft Top Woes
« Reply #1 on: June 16, 2010, 09:49:18 PM »
If you need the rail that attaches to the top of the window frame I have a free one...
'10 JK unlimited
-Henry Ford
Re: Soft Top Woes
« Reply #2 on: June 16, 2010, 10:48:39 PM »
jpthing, the rail should have the latches on it then?
i am pretty sure i can get you a frame cheap.  then you are done.  i will let you know before you come get the windows and screws.
Offline BlackAura
Re: Soft Top Woes
« Reply #3 on: June 17, 2010, 12:20:40 PM »
Sweet, thanks guys!
BlackAura (Kevin)
