Author Topic: speedo gear  (Read 1375 times)
Offline Pookapotamus
speedo gear
« on: June 21, 2010, 10:30:20 AM »
so where can i get a new speedo gear so that i can fix my speedo now that i have 4:10's?
i allready know the gear and part number of it but where do i go? napa?
Re: speedo gear
« Reply #1 on: June 21, 2010, 10:34:43 AM »
ebay or dealership or online jeep parts places
what size tires?  my old one may work
Re: speedo gear
« Reply #2 on: June 21, 2010, 10:51:47 AM »
Which one do you need?  I may still have some.  I can't remember if I got rid of them or not
Offline jeeptastic
Re: speedo gear
« Reply #3 on: June 21, 2010, 11:41:08 AM »
Hey BlackYJ do you have a speedo gear to work with 4:56 gears? If you have a spare one I would really like to buy it from you.
Re: speedo gear
« Reply #4 on: June 21, 2010, 11:46:44 AM »
part # 52067637 (37 tooth)
mr. speedo  $159.12
big 4 $137.55
modern $57.20 (can only get a 36 or 38 tooth)
Re: speedo gear
« Reply #5 on: June 21, 2010, 11:54:45 AM »
my new one was about $110 at courtesy with our discount.
so you are running 32" tires?  my old one is 36 tooth $30 if ya want it.
Re: speedo gear
« Reply #6 on: June 21, 2010, 11:59:10 AM »
running  31's but i will take it al and thanks! i will send you a pm
Re: speedo gear
« Reply #7 on: June 21, 2010, 12:06:38 PM »
31 is a 38 tooth.  my 36 was for 33/4.11  so OK if you have 33's in the near future.  but for 31's you will be off by a bit.. 10% or so i think.
Re: speedo gear
« Reply #8 on: June 21, 2010, 12:09:18 PM »
the chart i came accross said to use a 37 but the 36 should be just fine!
Re: speedo gear
« Reply #9 on: June 21, 2010, 12:11:28 PM »
Offline JENSSEN
    • Racing For The Cure
Re: speedo gear
« Reply #10 on: June 21, 2010, 01:24:37 PM »
http://www.4x4xplor.com/speedo.html
Found this on that link, if its correct for all Jeeps I am not sure.
By that chart I need a 31 tooth or 32 tooth
www.racingforthecure.ca
